Multiple screens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-24-2013, 04:21 PM - Thread Starter
Jeff Ellermeyer's Avatar
In researching screens and considering aspect ratios, I have come to the conclusion that perhaps having multiple screens is the best solution for my situation. Here is my logic.
I have a 13 foot wide room that is 19 feet long. I have art on the back wall, I want motorized projectors. I want to have a max width 2.35 screen. It seems like it would be better to have another max width 16:9 screen as well. This would be a different height than the 2.35, so they would both be immersive. I have been looking at the Panasonic PT-AE8000, so with the lens memory, it would not take long to refocus. That being said I would have to retract and lower the other screen. I think this is ok as I don't want TV and only really watch one movie at a go.
Any flaws in my logic?
Jeff Ellermeyer is offline
post #2 of 3 Old 07-25-2013, 03:49 PM
Mike Garrett's Avatar
Quoted: 5562 Post(s)
Liked: 3542
Need to know what you consider max width. You will have to make sure that the projector will be able to light up the screen. If wanting to go real large, you might consider the HP screen, but only if you can mount the projector slightly above seated head height.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 3 Old 08-07-2013, 02:16 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3037 Post(s)
Liked: 2969
Considering that I have used a 2.35:1 and a 16:9 screen - both motorized electric screens - for many years, I see no flaw in your logic. Check out the photos in my theater gallery. By the way, I don't find I need to re-focus. I do however have to re-zoom, since my screens are different widths.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Reply Screens
