Floating ceiling mount screen OK? - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2013, 11:05 AM - Thread Starter
djkms's Avatar
Quoted: 57 Post(s)
Hello all,
I am in the process of setting up another projector in my living room. In homes past I just made DIY fixed frame screens with blackout cloth. This time around I am looking at picking up a Elite 110" motorized screen (VMAX110UWH2). The projector will be a Optoma HD25-LV.
The problem is my throw wall. The screen will be going over the top of my fireplace, which is stone that protrudes from the wall. So I will have to mount the screen from the ceiling and have it about 4" from the wall. Can the screen safely just float down or does it need to rest against a wall? If it needs to rest against a wall I was thinking about running 2x4"'s down the length of the wall for the screen to rest against. Any other thoughts or suggestions appreciated.
Kris
Kris S
djkms is online now
Old 07-29-2013, 12:43 PM
DvdJags's Avatar
Quoted: 24 Post(s)
Liked: 40
I do not see a reason why you cannot do that. This is what I did to ceiling mount my screen. Make sure you find studs to hang the screen from.
DvdJags is offline
Old 07-29-2013, 12:52 PM
DvdJags's Avatar
Quoted: 24 Post(s)
Liked: 40
It's a 159" electric screen and floats down without requiring any support behind it.
DvdJags is offline
Old 07-31-2013, 12:12 AM - Thread Starter
djkms's Avatar
Quoted: 57 Post(s)
Good to know, thanks for the help!
Sent from my DROID BIONIC using Tapatalk 2
Kris S
djkms is online now
