PULLDOWN OR MORTORIZED SCREEN?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-18-2013, 04:38 PM - Thread Starter
udtsealeod's Avatar
Is there any quality difference between a manual pull-down screen and a motorized screen?? If so, what should I be looking for and by who? Recommendation??
Elements:
Basement open HT 15' x 26', minimum light, 2 rows of seating with rear 9' long counter table (3rd row)
60" Plasma HDTV mounted on wall
External Definite Tech Speaker system
Looking at a 110"-120" screen ceiling mounted
Most of the daily watching will be on the plasma, movies and events on projector.
FREEDOM ISN'T FREE
USN, CDR, RET
UDT/SEAL-EOD 1971-2003
udtsealeod is offline
post #2 of 2 Old 08-19-2013, 09:01 AM
Mike Garrett's Avatar
Quoted: 5590 Post(s)
Liked: 3578
Usually you are limited in fabric choices for manual screens. In other words, the better fabrics come on the higher priced tab-tensioned screens.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
