Aluminum Frame? - AVS Forum | Home Theater Discussions And Reviews
Old 08-25-2013, 06:57 PM - Thread Starter
jafa123's Avatar
I am considering an aluminum frame. Light weight, strong and can hoisted easier than the EMT (that as a frame only is heavy). Just wondering if anyone else besides the two I have read about has any feedback to this? I plan to use 1 inch aluminum square tubing. I plan on welding the aluminum to make the 10 x 20 frame including welding aluminum eye-bolts at the top to hoist up with my pulley system. I will paint the aluminum to prevent hot spots.
Any thoughts would be appreciated. I am hoping that with this light weight, if it fell, it wouldn't kill anyone.
Running out of options since I plan on buying a Carl's flex-white screen $$$. I want to be able to put it up and take it down with ease.
If this is the wrong place, can an admin move to the correct location?
jafa123 is offline
Old 08-27-2013, 11:05 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I think you want to post this in the DIY Screen Forum.
http://www.avsforum.com/f/110/diy-screen-section
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
