Help deciding on cheap screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-29-2013, 04:14 PM - Thread Starter
djtheg33k's Avatar
So, I've been doing a bit of research and shopping for my mini-theater I am putting together next week. I have Narrowed my projector choice down to the BenQ w1080st or the Optoma GT760. As far as screens are concerned, I have been flirting with the idea of either getting an Elite 100 Cinemawhite, 1080p2, or Airbrite 3d. While looking through those options, I discovered that my local Microcenter has an Inland 100inch fixed frame screen 50 bucks! Has anyone had any experience with this screen? I know it wont be the best, but maybe it's a good interim screen.
About the Screen:
100 inches
2.8gain
Aluminum alloy frame with black velvet surface
Flexible PVC Screen
About me:
Using Short Throw Projector
Mostly gaming/movie nights with the wife
Room is 11x13
Plan for screen placement is across a window with blackout curtains installed
UPDATE:
I went ahead and bought the screen (50 bucks is a drop in the bucket really. Good enough to at least test the screen). I'll give impressions next week when I get the projector and set it up. It is a Inland ProHT 3D Projection Wall Screen. 16:9 ratio @ 100 inches Fixed Frame. $49.99 @ Microcenter
http://inlandproduct.com/100fixedframescreen169.aspx
Sonyad likes this.
djtheg33k is offline
post #2 of 6 Old 09-03-2013, 12:12 PM - Thread Starter
djtheg33k's Avatar
So I have officially set up the screen and it looks pretty damn impressive for 50 bucks! If you have a Microcenter near you and it's in stock, I highly recommend it. Price dropped to 40 the other day.
post #3 of 6 Old 09-03-2013, 03:00 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Is it a grey screen? My local Microcenter had them in stock and I ordered and it's ready for pickup. I don't need it and don't really have a place for it but obviously I have a deal sickness.
Sonyad is online now
post #4 of 6 Old 09-03-2013, 06:23 PM - Thread Starter
djtheg33k's Avatar
Lol @ deal sickness that we both share. Yes, it is a gray screen. It has a high gain but is definitely good stuff. Made with soft PVC and easy to put together
post #5 of 6 Old 09-05-2013, 03:26 PM
smithmat's Avatar
I am thinking about picking this up. Can you provide the dimensions of the assembled screen? I am really interested in the total width.
smithmat is offline
post #6 of 6 Old 09-05-2013, 04:39 PM - Thread Starter
djtheg33k's Avatar
Sure! The dimensions are :
96.46” x 6.29” x 6.29”
Reply Screens
