I Need help with picking a screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-08-2013, 09:14 AM - Thread Starter
maxvalocity's Avatar
Ok so I am building a theater room in my basement and need help picking a screen for it. My projector that I have chosen is the benQ 1080st. I have about 75" that's from the front of the projector.
Screens under consideration:
1:) Elite Screens ELECTRIC125H-A1080P2 Spectrum Projection Screen acoustic pro
2:) Elite Screens ELECTRIC125H Electric Projection Screen max white
3:) Elitech 120" Electric Screen 16:9 HDTV Format High Contrast Grey
That's what I have so far these are all on amazon, I will take suggestion on these ones and others.
Budget is $500 with shipping
No windows in the room.
maxvalocity is offline
post #2 of 2 Old 09-11-2013, 02:12 PM
tanveers's Avatar
The options that you have listed are pretty good choices especially No.3. Have you got a chance to take a look at Da-Lite Screens? Da-Lite's are a Projection Screen standard in the industry. They are made with high quality material and allow some of the purest images around. There are a few in your price range of $500. You should give them a try and let me know how things go with your setup. Quick Note! If you ever want to try some of their products out and rent one take a look at the link here http://aarental.com/projector-screen-rental/
Give them a try, test them with your setup and see what fits you best!
Ben
Lead AV Tech, AA Rental
tanveers is offline
Reply Screens
