Screen for Sim2 C3Xe? (screen inovations). which one? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-15-2013, 11:43 PM - Thread Starter
08-450dually's Avatar
So I need to buy a 10ft wide screen for my Sim2. Its a 3 chip dlp putting out 2500 ansi lumens. Using it 1.8 screen width away from pj. Thinking of Screen Inovations (not the black diamond) but they have a Pure white and a Pure gray at 0.85 gain. Should I purchase the gray or do the white? Room is light controlled but not bat cave. These are the specs:
DLP™ Display Technology
2500 ANSI Lumens
1280 x 720 Native Resolution
16:9 Native Aspect Ratio
6800:1 Contrast Ratio
thanks
Jaime
08-450dually is offline
post #2 of 8 Old 09-16-2013, 09:57 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4122 Post(s)
Liked: 4209
I'd probably go white, but it sort of depends on what you watch and how you watch ( some lights on, no lights on etc. ). 10' wide is pretty big, and you don't really have that many lumens to play with ( once it's calibrated and you have a couple of hundred hours on the lamp ). Give me a call to discuss more.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3 of 8 Old 09-16-2013, 10:08 AM
roxiedog13's Avatar
Quoted: 1900 Post(s)
Liked: 784
2500 ANSI Lumens
thanks
Jaime
I have the Screen Innovations Solar 4K which is 1.3 gain ( actual measured is 1.37 gain) . I am currently using a Sony HW50ES which is 1700 lumens and for 2 D on 9 foot 2.35 this is plenty .
For 3D I only run a 7 foot wide 16:9 CIH. I would say it is good but I would like it a little brighter.
I plugged in your Projector on the same calculator see here : http://www.projectorcentral.com/Sim2-Crystal_35-projection-calculator-pro.htm?add=6291
If you use the same screen as I have you would be about 25% brighter and that is hard to perceive as a difference. In short I think you would be too dim for 3D but ok for everything else. If you went with
a super high gain screen in the 2.5 range you would be 39% brighter.
If 3D is not an issue you will be happy at 1.4 gain using something like my Solar 4K at 1.37 gain. For 3 D you would need to go high power to get the maximum benefit . And the quirk with high gain
screens is that your PJ has to be mounted at the center of the scree height to be effective.
Dedicated Theater: Sony VPL VW 675ESB , Panamorph Paladin Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Panasonic UB900, Oppo 203
Lumagen Pro 4440 , Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is offline
post #4 of 8 Old 09-16-2013, 10:13 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4209
Don't use that calculator - the lumens rating are not accurate. It uses the manufacturer's lumen spec's - they are not even close. It says my Lumis Host has 3000 lumens - calibrated, it is more like 1100 at best.
post #5 of 8 Old 09-16-2013, 03:29 PM
roxiedog13's Avatar
Liked: 784
I figured the same. Well, at least this is done with all manufactures , so the differences though not calibrated are somewhat close.
ALL manufactures should have to post lumens for various scenarios.
Car manufactures do this with gas mileage figures. They post mileage for a car optimized for perfect conditions. Flat roads, lowest highway speed, perfect road surface, flat road, temperature, tires
stripped down car etc.etc,etc. Then when you drive the thing best you will ever get real world is 60% of the published.
post #6 of 8 Old 09-16-2013, 04:14 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4209
The differences aren't close - they are all over the place. First, you need to find a trusted review like the ones Art does at Projector Reviews - http://www.projectorreviews.com/
Then you need a good screen gain program that not only shows how many foot lamberts you will get, it should also graph the foot lamberts as the lamp dims with age. Only then will you have an idea how bright a given screen will be.
post #7 of 8 Old 09-16-2013, 04:28 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4209
Here is a review of the OP's projector - http://www.projectorreviews.com/sim2/grand-cinema-c3x/performance.php
Calibrated lumens - 1100. On a 120" wide screen with 1.1 gain that would produce 21.54 foot lamberts with a new lamp ar full power. Not too shabby.
post #8 of 8 Old 09-16-2013, 11:07 PM - Thread Starter
Thank you all for your input. I read that write up on the C3X, but my projector is the "e" version which puts out much more lumens. Hence, I question if I should go gray instead of white.
Reply Screens
