Dual masking motorized screen options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-16-2013, 02:24 AM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
Hey all
I'm looking for a screen upgrade, specifically a high-contrast (i.e. gray) motorized 2.35 ratio screen with a masking system to drop it to 1.78. Size should be between 54" and 58" high.
As far as I can tell only Da-Lite offers this, with the High Contrast Cinema Vision material: http://www.da-lite.com/products/product.php?cID=33&pID=400
I would prefer a Black Diamond 1.4 or Stewart Firehawk G3 over the Da-Lite HCCV, based on samples and reviews, but doesn't seem like they offer a masking housing. Do I have any other options? Maybe some add-on?
Pyxle is offline
post #2 of 10 Old 09-16-2013, 11:00 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2969
Stewart makes several - http://www.stewartfilmscreen.com/residential/products/variable_masking_dedicated_fixed/variable_masking_quick_refrence/variable_masking_quick_refrence_residential.html
The Firehawk is much much better than the HCCV material IMO. I've owned both.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3 of 10 Old 09-16-2013, 12:18 PM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
To be clear the screen itself needs to be retractable as well...are those?
Pyxle is offline
post #4 of 10 Old 09-16-2013, 02:31 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2969
Yes, they do make them - http://www.stewartfilmscreen.com/residential/products/variable_masking_multimedia/variable_masking_quick_refrence/variable_masking_quick_refrence_residential.html
However, you could consider what I did - getting 2 screens - one 2.35:1, and one 16:9. Might cost less overall.
post #5 of 10 Old 09-16-2013, 03:20 PM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
Oh! Somehow I missed those.
Do you have focus issues with the 2 screens? Are they identical except for the aspect ratio?
Pyxle is offline
post #6 of 10 Old 09-16-2013, 04:38 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2969
No focus issues - they are only about 4 inches apart. And no, the 2.35:1 screen is a StudioTek 130 G3 - 118" x 50' x 128' diagonal. The 16:9 screen ( currently a Da Lite HCCV - 106" x 59.6" x 121.6 " diagonal ) is in the process of being replaced with a Stewart Neve 1.1 screen. The best of both worlds, and less expensive than most electric masking screens.
http://cdn.avsforum.com/4/4a/900x900px-LL-4a0ca2a0_IMG_1391.jpeg
Just a different idea to think about.
post #7 of 10 Old 09-16-2013, 07:12 PM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
Hmm ok. List prices tell the tale I guess.
Vertical ElectriScreen ElectriMask EMC128SFHG3-12-3-5 - $9,606 list
versus
Luxus Model A LX100HFHG3-12-2-5 - $4,228 list
Luxus Model A LXC125SFHG3-12-3-5 - $4,939 list
= $9,167 total list
Although the 125" is slightly smaller. I'll send you an email.
Pyxle is offline
post #8 of 10 Old 09-17-2013, 12:20 PM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
Would a reasonable option be apply the Silver Fire paint mix to a cheap masking screen like the Da-Lite Dual Masking Electrol?
It's not clear to me if Silver Fire DIY is better or worse than the Da-Lite HCCV.
Pyxle is offline
post #9 of 10 Old 03-29-2015, 12:51 PM - Thread Starter
Pyxle's Avatar
Quoted: 44 Post(s)
The answer I think is no, it would not be reasonable.
Pyxle is offline
post #10 of 10 Old 03-30-2015, 04:02 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2969
I would have to agree. I've been very happy with my 2 screen set up.
Reply Screens
