Is There A Way To Hang A Da-Lite Perm Wall Screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-16-2013, 09:40 PM - Thread Starter
John Clark's Avatar
Quoted: 86 Post(s)
Liked: 24
I'm about to order a Da-Lite Perm Wall 133inch in HiPower. This will be replacing a DIY screen, on a very solid frame, that I made some years back, which hangs from the ceiling. I'm trying to determine, in advance, if there is some way to do the same with the Perm Wall model. The wall it is located next to does not really allow wall mounting, as the lower half is poured concrete and the upper half, is six inches back from the lower. My thought is that there must be some top frame element that could be drilled with two holes to hang the screen, but I would like to confirm it's possible before ordering. Any input would be appreciated. Thanks.
John
John Clark is offline
post #2 of 3 Old 09-17-2013, 06:14 AM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
When I was trying to hang my Dalite Model C I called Dalite tech support..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 3 Old 09-20-2013, 09:21 PM - Thread Starter
John Clark's Avatar
Quoted: 86 Post(s)
Liked: 24
Thanks for the suggestion, Doug. I talked to Da-Lite. Apparently, if I really want to do this, they are recommending that the only way to manage it is to have a sheet of plywood cut to the screen size, and mount the screen (on it's frame) to it.
John
Reply Screens
Da Lite Perm Wall High Contrast Cinema Vision Projection Screen 106 In
