Do I have to mount the screen to the wall? - AVS Forum | Home Theater Discussions And Reviews
Old 09-23-2013, 09:32 PM - Thread Starter
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
So I'm about to take a leap into the projector/screen world. I have the perfect room for it with virtually no ambient light. However, the ideal wall to place it on is not flat. There is a 2ft wide trust that sticks out 14" from the rest of the wall.
I really want a fixed frame, can I just set it on my current tv stand? Are they typically deep enough to stand up on their own?
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
Old 09-24-2013, 06:37 PM
FilmReverie's Avatar
Quoted: 14 Post(s)
Liked: 74
I can't speak for all screens but from what I have used they need something to hold them up. I'm sure you could create your own stand somewhat like what painters do with a canvas. I don't think you would be happy leaning it of your tv stand as it will have to be on an angle then. You need something to keep it straight and so it doesn't move.
I have never tried not mounting a fixed screen though, if you do come up with any ideas be sure to share them as i'm sure there are others in a similar situation to you.
FilmReverie is offline
Old 09-28-2013, 10:07 AM - Thread Starter
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
I purchased an elite screens, sable, 100" 16:9 fixed frame. the frame is actually thick enough it stands on my short tv stand. it rests on there just fine, I secured it to the small section of the wall behind it with 3M command Velcro straps and it is plenty secure and looks great.
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
Old 09-28-2013, 05:01 PM
Quoted: 14 Post(s)
Liked: 74
