Replace old Da-Lite Da-Tab Electrol with HD Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-26-2013, 03:51 PM - Thread Starter
ddell's Avatar
Hi, I recently updated my projector to the Epson 5010E and I'm looking to replace my old 4-3 Da-lite screen with a 16:9 screen - probably with another vendor, since I, too, have been affected by the greasy breakdown of the vinyl in the Da-Lite. Throw is 129", and viewing distance about 132" (projector in a wall-mounted cabinet above the heads of the viewers. Projector is 2400 lumens. Ambient light varies a lot, but can be high. Usually quite low for evening viewing. I was 85" 4:3, and thinking of going with an 81" diagonal 16:9 which will keep the height to the 40" allowing for a non-seam Stewart screen if I'd like. One special requirement, while I don't want a perforated screen, I do want a perforated blackdrop as my center speaker is mounted above the TV cabinet. This may rule out a standard ceiling mounted screen...
Thoughts, Suggestions, Warnings?
David
David
ddell is offline
Reply Screens
Epson 5010 E Powerlite Home Cinema 3d Front Projector With Wirelesshd , Da Lite 94025
