Can I use a High Gain screen but still keep my PJ as a ceiling mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-04-2013, 08:05 PM - Thread Starter
roxiedog13's Avatar
Quoted: 1691 Post(s)
Liked: 690
I want to use a high gain screen for 3D only to make up some of the light losses. I know mounting the PJ high is not ideal but what will I loose by keeping the PJ at the height of the top of the screen and say using a HP 2.4 or 2.8.
I already have a 2.35:1, 120" diagonal Screen Innovations solar 4K which is actually measured to be 1.37 gain. 2D is fine, 3 D a little dim for me and that is running 3D on a a 16:9 @ 95" diagonal .
I just figured if I bought a second screen to drop for 3D only maybe I would gain back some of the light lost using the glasses. If I have to drop the PJ too that will be a bit of an issue.
Dedicated Theater: Sony VPL VW 675ESB , Panamorph Paladin Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Panasonic UB900, Oppo 203
Lumagen Pro 4440 , Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
post #2 of 10 Old 10-05-2013, 05:47 AM
airscapes's Avatar
Quoted: 379 Post(s)
Liked: 302
The 2.8 HP is no longer made, you can only get them in the used market.
You will gain another screen that is no brighter than the screen you have. Max gain is with the projector placed so your audiences eyes are within 12-14 inches of the lens height. People will tell you to use the calculator to see what gain you will get but if you don't plan on doing it correctly don't do it. I own the 2.8 and have had the 2.4in my home for a week and if you fail to follow the rules of physics you won't get the results you are looking for.
This is the type of placement I am talking about for best gain. Better yet would be to have the projector farther behind and up just over my head height to widen the max viewing cone. This setup works fine for the 3 chairs but my center chair is the cats meWOW The light is being reflected directly back to the lens so you need to be in that path.
Here is what a 2.8 gain looks like when you take a flash picture and you are getting full gain.
Here is what the same screen looks like with no flash
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 10 Old 10-05-2013, 08:25 AM - Thread Starter
roxiedog13's Avatar
Liked: 690
I cannot do this position with my PJ so I guess you answered my question perfectly and I expect this answer to be honest.
I'd say the best I can do is stack a second PJ to get the extra brightness, even then I'd say not practical for anything except 3 D.
post #4 of 10 Old 10-05-2013, 08:42 AM
nickoakdl's Avatar
Quoted: 79 Post(s)
Liked: 63
Can you get a drop extension for the projector?
nickoakdl is offline
post #5 of 10 Old 10-05-2013, 11:15 AM - Thread Starter
roxiedog13's Avatar
Liked: 690
Yea, I could put a drop extension, would still be only about 1/3 the way down the screen I believe. If I do this I would install two things.
One would be a electric drop for the PJ, the second would be a electric drop High Gain screen but would have to keep the height a little
higher than my fixed wall screen so that I keep the screen closer to the straight line of the PJ and thus maximize the benefit of the 2.4 gain
screen .
This would give me the best for both 2D and much improved situation for better for 3D . Actually, I could probably make one more change
and that would be to move the high gain screen position about one foot closer to the PJ, which would be closer to the viewers as well. This
will also help to improve the reflected brightness and at the same time create a bigger field of view for the audience.
post #6 of 10 Old 10-05-2013, 11:41 AM
airscapes's Avatar
Quoted: 379 Post(s)
Liked: 302
screen .
Having the projector and the screen line up is not the goal. The goal is to have your projector and eyes line up.. If you did what you said, you would need to stand under the projector to get the gain.. you want the gain where your eyes are when sitting .. Hope that makes sense.
Doug
post #7 of 10 Old 10-05-2013, 01:18 PM - Thread Starter
roxiedog13's Avatar
Liked: 690
Yes, makes sense. What you are saying is that I need to keep the PJ on the ceiling and raise the seats 4 feet biggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifbiggrin.gifwink.gif
I had another look at my setup and really, the best I can do is have the PJ one third the way down from the top of my screen, my first row seating puts ones eyes at about one third the height of the screen ( the recommended height) and the second row about half way up the screen.
Cannot see how the two ( eye height and PJ center) can line up anyway unless the center row of seats is out, otherwise you would be projecting partially on the back of the seat.
post #8 of 10 Old 10-06-2013, 05:40 AM
rcohen's Avatar
Quoted: 1377 Post(s)
Liked: 604
Have you tried covering up that mirror?!
It seems like right behind the projector on a high gain screen would destroy contrast.
rcohen is offline
post #9 of 10 Old 10-06-2013, 06:47 AM
airscapes's Avatar
Quoted: 379 Post(s)
Liked: 302
Yes, the mirror gets covered every night. I use a black twin sheet with these cloth picture hooks sewn across the top and sides to attach it.
http://www.dickblick.com/products/cloth-picture-hangers/
I hang 4 velvet panels on each side of the screen (magnets), cover the picture and DVD cabinet with black fabric as well as the mirror.
One thing to note, the mirror does not seem to effect the image as much as you would think.. There are times I forget to put it on and never even notice. The wall and ceiling that makes a huge difference.
Doug
post #10 of 10 Old 10-07-2013, 06:36 AM
rcohen's Avatar
Liked: 604
Interesting. At our office, we have a big HP screen, and stray light at the back of the room has an exaggerated effect. Perhaps it's the difference between ansi and on/off contrast, since your light would be timed with bright images. On the flip side, stray light off axis has a reduced effect. No surprise that diffuse light near the screen is bad, though.
rcohen is offline
Reply Screens
