Beginner needs help choosing a screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-09-2013, 05:03 PM - Thread Starter
infin|ty's Avatar
Hi all,
I've been tasked with helping my brother-in-law choose components for a basement home theater build he is embarking upon. We are looking to get a nice projector and 5.1 setup going. I did some research and I think we've settled on this projector:
http://www.amazon.com/BenQ-W1070-1080P-Theater-Projector/dp/B00A2T6X0K
Given that, I'm really lost when it comes to a screen. There is probably only going to be one row of seating (Big modular sectional), which will be approximately 13-15' from the screen. There is going to be almost no ambient light, as it will be in a basement.
That being said, I need help choosing a screen size and model. I'm thinking somewhere between 108"-120" would be reasonable, I feel like going bigger might tax that projector in terms of brightness, as well as being a bit overwhelming from the viewing distance we are working with. Also, I think a fixed screen will work best, as there is no need to motorize it etc. Also, if there is a good option in the $300 range, even better.
Please feel free to correct me or steer me in the right direction. He's leaning on me to help him out and this is one area I have very little knowledge. Thanks guys.
infin|ty is offline
post #2 of 12 Old 10-10-2013, 01:18 PM
utee05's Avatar
Quoted: 44 Post(s)
I would go for a fixed screen if possible. It would be best to throw the image on a wall or sheet to help you determine how big of a screen you can handle.
I have a w1070 and currently throwing the image on a bed sheet to get an idea of what size of screen I like. I sit 12' away and am probably going to get a 120" screen.
How far away is the w1070 from the wall you will be projecting to?
utee05 is offline
post #3 of 12 Old 10-10-2013, 04:15 PM - Thread Starter
infin|ty's Avatar
It's going to be ceiling mounted 12' from the wall. Based on the BenQ calculator, my options for size are 111"-144".
infin|ty is offline
post #4 of 12 Old 10-20-2013, 08:21 PM - Thread Starter
infin|ty's Avatar
Any thoughts folks?
infin|ty is offline
post #5 of 12 Old 10-21-2013, 12:15 PM
utee05's Avatar
Quoted: 44 Post(s)
I recently got an Elunevision Reference 4K Tab-Tension 120" screen for my W1070. My projector is 13.5' away from the screen and I sit 12' away from it. I am glad I went with 120" as I was debating between a 120" and a 106".
I would recommend throwing the image onto a wall or sheet to get an idea of what size screen to get. This is what I did for about a month and that was how I settled on getting a 120"
I would look at elite, monoprice or visual apex or jamestown for screens. I am not too familiar with all of the fixed screens but you can also go the DIY route.
utee05 is offline
post #6 of 12 Old 10-30-2013, 11:09 AM
a|F
a|F's Avatar
Quoted: 24 Post(s)
Liked: 25
How do you like the picture on the 4k screen?
a|F is offline
post #7 of 12 Old 10-30-2013, 05:00 PM
Nuke61's Avatar
Quoted: 18 Post(s)
Originally Posted by infin|ty View Post
Any thoughts folks?
I'm getting my first projector in a few weeks, when we move into our house. It's going into a room dedicated to HT use, and what I'm going to do is what utee05 suggested, which is to project the picture onto the wall for a while to see what I'm comfortable with. My inclination at this point is a fixed screen of 120" with a 1.1 gain. It's this screen off of Amazon: http://www.amazon.com/Silver-Ticket-HDTV-16-Projector/dp/B00CYLOTPK/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2AU09QKFKA23D&coliid=I2GR7SPV2W1DBZ or something similar from a site vendor.
But at first I'm going to do the suggested project it on the wall and sit where I plan to sit, just to make sure the lighting is going to be O.K., and the size is comfortable.
Nuke61 is offline
post #8 of 12 Old 10-30-2013, 06:58 PM
utee05's Avatar
Quoted: 44 Post(s)
Good luck with your setup. It may take you a bit to get used to the larger screen size. It took me a while to but now I really can't see a movie anywhere else.
@a|F I really like the image I get on my 4K screen. It was a huge jump from my bed sheet smile.gif I really don't have anything else to compare to but I am very pleased and there aren't any wrinkles or anything. I am still using it more and breaking in my projector. I do not think I have hit 100hrs yet on my w1070.
utee05 is offline
post #9 of 12 Old 11-04-2013, 10:01 AM
gec5741's Avatar
Quoted: 202 Post(s)
Liked: 92
I agree your best bet is to save the screen for last. I am in the middle of building a media room in the basement and I've decided to not worry about the screen just yet. I plan to throw the image on the wall for a bit at first and play around with size and res before commiting to a screen.
gec5741 is offline
post #10 of 12 Old 01-12-2015, 08:30 PM
prince.nothing's Avatar
Quoted: 87 Post(s)
How are you enjoying your screen? I'm looking for a 120" electric tab tension screen and appreciate your feedback.
My Home Theater Build: Geeky Talkies
prince.nothing is offline
post #11 of 12 Old 01-12-2015, 08:37 PM
utee05's Avatar
Quoted: 44 Post(s)
I'm really enjoying it. Not problems at the moment. I did have to put some black velvet cloth in the back since my screen is in front of a pair of windows. If you have it in front of any sort of window it will need something behind it since the backing does not block out the light.
The image looks great even with my W1070. Nice picture and was easy to mount to the wall.
utee05 is offline
post #12 of 12 Old 01-12-2015, 08:39 PM
Viper777's Avatar
I have a 100" EliteScreen Evanesce-B electric in-ceiling projection screen. I love it. Picture looks great, good contrast, and even though its not a tab-tension, it hangs very flat. You can't see any ripples in the image head-on. You can see some very slight ripples if you look at the screen sideways with the picture off. It was a very big upgrade from the Da-lite 120" outdoor projection screen I was using (which was too big for the room anways).
The also have a version with tab-tension, for about $200 more. My screen was around $450 from EliteScreen store. I think the 120" Tab tensioned version would be around $650 or $700.
I went with the un-tensioned version because it was green certified, and I believe had less of the vinyl smell.
Viper777 is offline
Reply Screens
