Draper MS1000V ambient light rejection screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-05-2013, 12:08 AM - Thread Starter
Skylinestar's Avatar
Quoted: 1207 Post(s)
Liked: 225
Has anyone seen the Draper MS1000V screen? It was demoed at CEDIA 2013.
Pros and cons? Any sparklies / sheen?
How does it compete against SI Black Diamond 1.4?
Info from Draper Inc
Skylinestar is offline
post #2 of 14 Old 11-11-2013, 05:04 PM
PSHK's Avatar
Looks like it's just the 2 of us looking into this screen at the moment...wink.gif
Anyone else......?
PSHK is offline
post #3 of 14 Old 11-12-2013, 11:19 AM
karlsch's Avatar
Quoted: 39 Post(s)
Liked: 56
I have a Black Diamond 0.8 that I want to replace because of the sparkles/hot spotting.
I considered replacing it with a MS1000V so I got a sample from Draper.
I taped the MS1000V sample to various places on my BD screen and found that the sparkles are at least as bad with MS1000V and the ambient light rejection is not as good.
Karl S.
karlsch is offline
post #4 of 14 Old 11-12-2013, 11:38 AM
karlsch's Avatar
Quoted: 39 Post(s)
Liked: 56
I should add to my above post that in addition to the MS1000V sample, I also taped a pure white screen sample to my BD screen to make sure that the sparkles I was seeing were not caused by my projector or something else.
I could see no sparkles on the white screen sample.
Karl S.
karlsch is offline
post #5 of 14 Old 11-12-2013, 05:39 PM
venkatesh_m's Avatar
Quoted: 38 Post(s)
Liked: 27
Was this the latest samples? I did hear that the initial samples sent out by Draper were orientated to the wrong side.
venkatesh_m is offline
post #6 of 14 Old 11-12-2013, 06:12 PM
karlsch's Avatar
Quoted: 39 Post(s)
Liked: 56
I read about that problem.
My sample is apparently correct. The back side is very shiny, and the front side is much less shiny - more of a satin finish.
Karl S.
karlsch is offline
post #7 of 14 Old 11-12-2013, 09:28 PM
Quoted: 38 Post(s)
Liked: 27
That's too bad. I will post my observations when I setup mine. Mine would be the react 2.1 though, but I believe they r the same.
Sent from my GT-I9100 using Tapatalk
post #8 of 14 Old 12-04-2013, 05:37 AM
PSHK's Avatar
Wouldn't put too much on the sample....I tried with a sample of the euro React 2.1 material ( same as ms1000v), with poor results, especially as far as viewing cones were concerned.
...however, it seems the material only does it's magic after being fully tab tensioned - hence the sample is flawed unless you are stretching out at all angles.
PSHK is offline
post #9 of 14 Old 12-15-2013, 12:31 AM
shenyijing's Avatar
RjC5Kx
shenyijing is offline
post #10 of 14 Old 01-03-2014, 04:44 PM
C17FXR's Avatar
Venkatesh_m
Did you get your screen hung yet, interested in your results as I'm considering one of their screens with this material.
Also what screen did you get?
C17FXR is offline
post #11 of 14 Old 01-04-2014, 01:01 AM
Quoted: 38 Post(s)
Liked: 27
Originally Posted by C17FXR View Post
Venkatesh_m
C17FXR,
I did. I got the Draper React 2.1 Tab Tensioned screen (same screen as Draper MS1000V I believe). I have not seen any major sparklies on my setup. I think its a good ambient light screen considering the price. It does seem to be a gain of 1.0. I am using it in a living room with white walls, white ceiling.
post #12 of 14 Old 03-05-2014, 09:23 PM
mlaverty's Avatar
I'm looking at this screen also. What is the viewing angle like?
mlaverty is offline
post #13 of 14 Old 03-19-2014, 02:11 PM
embeathome's Avatar
72 degrees. Is this enough - that's my question...
embeathome is offline
post #14 of 14 Old 03-20-2014, 08:07 PM
noah katz's Avatar
Quoted: 1095 Post(s)
Liked: 380
depends on your viewing angles
noah katz is offline
Reply Screens
Draper
