help selecting a screen - AVS Forum | Home Theater Discussions And Reviews
Old 11-21-2013, 12:10 PM - Thread Starter
madcity's Avatar
I have attached a couple of photos of my basement where the screen will be located.  It is going to go on the wall that is shared with the stairs.  From what I am reading it looks like a grey screen will be best but there are lots of options out there.  I will probably go with an Epson 3020 projector and a 120" screen.  Budget is $300 - $500 if possible but I don't want to sacrifice picture quality for a couple hundred dollars.
madcity is offline
Old 11-22-2013, 07:25 PM
hifibuyguy's Avatar
Quoted: 22 Post(s)
I'm interested in answers to this thread as well, I just pulled the trigger on an Epson 5030 today and a very similar basement area. I'll probably create a new thread but maybe someone can help me as well. I'm hoping to utilize my 55" vizio for "every day tv" and HTPC and have a drop down screen when watching a BR. My budget is right in the same ball park...but I really like the idea of Monoprice multi format fixed....hmmmm...
Emotiva XMC-1, Tekton Double impact, GoldenEar XXL center, Airmotiv 6's, GoldenEar Aeon 2's rear, Epik/DIY sub, Oppo DVD, Parts Express 15 sub kit, Epson 5030 projector, Crown XLS2500 X 4, 1 running the Tekton's
hifibuyguy is online now
Old 11-22-2013, 07:41 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Check the Elite or VAPEX screens. Also, check out Amazon for screen deals there too.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 11-22-2013, 07:42 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
If I had the option of a fixed screen, I would definitely go with a multi-format screen.
Joe = LFE Addict
jpmst3 is offline
Old 11-26-2013, 05:59 PM - Thread Starter
madcity's Avatar
what is the advantage of the multi format screen as opposed to just projecting the 2.35:1 image on the larger screen?  I assume it is to reduce the reflective surface area that isn't being used but does it really make a noticeable difference?
Do I need a gray screen or should I use a white screen?
madcity is offline
Old 11-26-2013, 07:31 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes, to eliminate the black bars/reflective area. The noticeability depends on many variables.
Gray helps in bright rooms and with low contrast projectors. If you can control the light white is the best option.
Joe = LFE Addict
jpmst3 is offline
Old 11-26-2013, 08:52 PM
neobendez's Avatar
VAPEX will probably do. And,also Amazon has a lot of deal on screen which I know you can save a lot!
neobendez is offline
Old 11-29-2013, 08:48 PM - Thread Starter
madcity's Avatar
gray screen or can get away with a white screen???
madcity is offline
