Originally Posted by Majister /t/1501120/has-anyone-tried-the-elite-cinegrey-5d-screen-yet/30#post_24656297
Nice feed back, also thanks to everyone who has posted info, pics and mini reviews.
Re the above comments, I just wanted to comment on one thing. In regarda to narrowing or broadening the cone. The further back the projecgor is, the narrower the cone. The closer it is the wider the cone. So when further back and zoomed in to compensate for the enlargment effect of moving the projector back, you end up getting into zoom...thats one of the greatest losses of light in a projection system.
The oerson you directed your comment at might want to look at getting a tall ladder, and just move the projector closer by increments and see if that helps. Now once he's closer, less zoom is used and you gain brightness and the cone is wider, the less oblique angle of the projector light vs the screen, might move his sweet spot into a more favourable position. Granted with increased brightness, maybe hotspotting could be more of an issue, but broadlh soeaking, I think this could increase his sweet spot. Might allow the couch to be moved forward a bit which helps get those rear surrounds more behind you.
Sorry for the long post. I'm actually assuming you just mixed it up in the typing, but its worth mentioning incase it causes confusion. But essentially, he has quite a bit of play room if he's willing to consider a more forward projector placement.
Hope this helps!
Cheers
