Has anyone compared the Dalite JKP 1.3 to Stewart Studiotek 130? (Plus other 1.3 gain options) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-25-2013, 05:48 PM - Thread Starter
Stiltz's Avatar
Quoted: 18 Post(s)
I have samples of both and the JKP 1.3 seems to be dimmer than the Studiotek 130.
Has anyone else noticed this?
I found it to be very close in brightness to the Cima Neve material. (ie. 1.1-ish)
Is there another 1.3-ish gain screen to consider besides the Studiotek 130?
I really want the highest gain screen possible with the least amount of issues as mine will be mounted in a media room. (yes, I know this is a pipe dream)
The DNP 23-23 was great, but sparklies ruined it for us. (hoping to get something 120"-135" at 13.5')
The Studiotek 130 does show a tiny bit of sparkle, but much less than the DNP and BD.
I would absolutely be happy with the Studiotek 130, but I'm having a hard time swallowing the $1k increase in price over the Cima Neve or JKP 1.3.
Media Room - JVC RS500 PJ, 130" Dalite JKP 1.3, Anthem MRX 1120 AVR, Panasonic UB900 UHD, Martin Logan Vantage, ML Stage, 4xML Motion FX, 4xML R Ceiling, PS Audio PWD, Seaton Submersive F2 / 2xOutlaw LFM-1EX / HSU MBM Subs, Dune 3D, Sonos, HTPC, 2xButtKicker
Family Room: LG 65EF9500 OLED, Marantz SR7010, Philips UHD, 2xMartin Logan Motion 15, ML Motion C2, 2xML Motion 2, 2xML IC Ceiling, REL T9 Sub, HTPC
Stiltz is online now
post #2 of 6 Old 11-27-2013, 08:49 AM
SAM SAM's Avatar
Have you tried the Pure White XT13000V surface from Draper.
AMAZING, they give free samples to :)
SAM SAM is offline
post #3 of 6 Old 11-28-2013, 05:02 PM
eric.exe's Avatar
Quoted: 16 Post(s)
I'm interested in people's opinion on these screen as well.
eric.exe is offline
post #4 of 6 Old 11-29-2013, 05:55 AM
Plasticfish's Avatar
I just purchased the JKP 1.3 about a month ago. It's 133" 2.35:1 screen and it's paired with the Sony VPL500. The image is awesome! I really cannot compare it to the other screens mentioned here, but I can report that the 1.3 JKP screen shows no sparklies - at least to my eyes. Image really is crisp.
Plasticfish is offline
post #5 of 6 Old 12-01-2013, 08:55 AM
Citation4444's Avatar
Quoted: 185 Post(s)
Liked: 145
The JKP 1.3 is significantly brighter than the Studiotek 130. See my earlier post http://www.avsforum.com/t/1499122/screen-sample-shoot-out-jkp-hd-progressive-1-1-and-1-3-studiotek-130-carada-bw#post_23953015
Citation4444 is offline
post #6 of 6 Old 12-10-2013, 10:51 PM - Thread Starter
Stiltz's Avatar
Quoted: 18 Post(s)
130" JKP 1.3 is on the truck and will be delivered Thursday morning!
It was a tough decision as I thought the Studiotek samples looked brighter, but the sparkles and added cost swayed me towards the JKP.
I also liked the Cima Neve and would have gone with it, but they don't do custom sizes and I decided that 130" was perfect for my throw.
Reply Screens
