Seymour Center Stage XD OR Seymour Screen Excellence 4k - AVS Forum | Home Theater Discussions And Reviews
Old 11-27-2013, 07:23 AM - Thread Starter
Lewis. S's Avatar
I am looking for a AT screen for my theater room
I have purchased all of the components other than the screen, the specs are as follows:
Room Size: No window room measuring 12.5 x 18.9 (16 feet back row viewing, 11 feet front row viewing)
Screen Size: 120 wide (137' diagonal - 16:9)
Projector: JVC DLA-X95RKT
Speakers: Definitive Technology RLS II (front L x R X C) - behind screen
Sub: Definitive Technology IW Sub Reference
Surrounds: Definitive Technology UIW RSS II (4 speakers)
Source: Oppo-95, Dune Smart, Direct TV
I am trying to decide between the Center Stage or the 4k - At my viewing distances (depending on what thread in AVS forum you read) I am at the cusp of appreciating the 4k fine weave, however other posts note that the Center Stage "pops" relative to the 4K (i.e. produces a slightly more enjoyable picture)
Any input is much appreciated
Best
Lewis
Lewis. S is offline
Old 11-27-2013, 08:29 AM
rolette's Avatar
I can't help with the 4K vs Center Stage material question, but my room is about the same size and I've got the 120" Center Stage XD (2.35:1) screen and I love it.
Couple of photos here along with some comments regarding viewing distances and weave visibility farther down in the thread.
Jay
rolette is offline
Old 12-17-2013, 09:45 PM
priyen13's Avatar
Best
Lewis
Hi Lewis,
I'm actually in a similar boat, my room is a little smaller (back row - 15, front - 10ish). Did you ever end up picking between the two? I have samples of both and the XD definitely pops but the 4k has a really fine weave. I'm stuck :\
priyen13 is offline
Old 12-20-2013, 01:26 PM - Thread Starter
Lewis. S's Avatar
Originally Posted by priyen13 View Post
Hi Lewis,
priyen13,
I have not - I am trying to find a place where I can see both and as of today I have not found anywhere
I have to make the call in about 30 days so I will let you know where things shake out
Best,
Lewis
Lewis. S is offline
Old 12-20-2013, 03:20 PM
priyen13's Avatar
priyen13,
Best,
Lewis
That's unfortunate (for me) haha. I have to make the call in less than 2 weeks. I think, weave aside, the price of the screenexcellence is hard to justify over the XD...
priyen13 is offline
Old 12-21-2013, 12:11 PM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 190
I've seen the XD sitting at around 8 to 9 feet. It looks really good. For me, I could not see the weave with the movie on and no lights. I could see a weave with lights on only. This was Spacemans. I ordered the EN 4K cause I'm going to be a little closer and I'm going with a 4K projector in my new room. It has less gain but is much tighter. I'm about two or three weeks from having mine up. I'll be able to give you a better opinion on the 4K at that time.
If you're just looking at the XD, you might want to check out the Falcon screen as well. It seems there are people that like it and it's around the same price. AVS sells them as well if you want to check with Craig or Mike.
7channelfreak is offline
Old 01-02-2014, 06:53 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Just call Chris at Seymour and ask for samples of both................
You'll have to pay for shipping and for 4k samples. I tested out all materials before I purchased...........the designer of my room spec-ed Stewart 130 MP, but I could see perfs at 12ft.
With the XD material, I could see weave at 12ft.........since my first row seating is at 12.5 ft, I went with 4k material. Your projector choice will help dictate XD or 4k..................XD is noticeably brighter than 4k. My projector is bright enough that the lower gain on the 4k screen is not problematic.
Here's the screen:
doublewing11 is offline
Old 01-02-2014, 07:00 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
doublewing11,
What size is your screen and what type of projector are you using? confused.gif
Glenn Baumann is offline
Old 01-02-2014, 07:07 PM
Quoted: 229 Post(s)
Liked: 938
Originally Posted by Glenn Baumann View Post
doublewing11,
12 ft 2.37 Seymour-SE 4k.......................I'm using a Sony 1000ES and both throw an exceptional picture! wink.gif
Old 02-04-2014, 09:47 PM
nathan_h's Avatar
Quoted: 1007 Post(s)
Liked: 600
When you guys talk about the gain difference, is this the spec difference or measured difference?
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
Old 02-10-2014, 06:34 PM
nathan_h's Avatar
Liked: 600
That projector has slightly more than twice the light output than my projector. Maybe yours is dialed down and mine is on high lamp mode, but I suspect the gap is significant smile.gif
In any event, I'm starting a line up of the AT materials currently available. Screen Innovations shipped today, Seymour is [not sure of status yet], and Falcon arrived today. It will be very interesting to measure each and judge which are acceptable -- balancing visibility of the weave with gain properties.
nathan_h is offline
Old 02-12-2014, 07:20 PM
ADDUpstate's Avatar
In my opinion, if you can afford the EN4k, get it. It's worth it. It's the best of the best. Screens don't get upgraded very often... You will likely never need to upgrade the screen, unless you want to go bigger. wink.gif Everything else in the chain of electronics will be upgraded much sooner. Buy once and be done with it.
ADDUpstate is offline
Old 02-13-2014, 08:28 AM
nathan_h's Avatar
Liked: 600
I agree that one should get the best screen one can, which is why my last couple of screens were from Stewart.
First, a Firehawk about a decade ago, since I was in a multi-use room and while I could turn off all the lights, I could not paint the walls dark.
Then an Ultramatte screen since I was going BIG in a dedicated bat cave, and at that time getting some extra gain was necessary for the better projectors at large sizes.
I don't know that the EN4k is the best for my application -- from a gain perspective. I requested a sample and will see. So far, the Falcon has hit the sweet spot in terms of gain and lack of visibility of the weave. But as I say, I have not received the Seymour EN4k yet.
nathan_h is offline
Old 02-13-2014, 03:19 PM
Quoted: 113 Post(s)
Liked: 54
Nathan,
I look forward to your observations between the Falcon and the EN4K! biggrin.gif
Old 02-13-2014, 05:31 PM
nathan_h's Avatar
Liked: 600
I'll be happy to share, but keep in mind, each situation is different (different room, different eyes, different projector, different size, distance, etc) wink.gif
snickers1 likes this.
nathan_h is offline
Old 02-14-2014, 10:06 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Why do you consider it the best of the best with such a dim picture? There's no way I could live such a dim picture. I've found with AT screens there's always going to be some time of trade off.
jbrown15 is offline
Old 02-14-2014, 10:08 PM
jbrown15's Avatar
Liked: 1993
If you want pm me your address and I'll mail you the 2'x2' sample that I have. All you have to do is pick up the tab to get it shipped. Might be a couple bucks, I could find out early next week if you're interested.
jbrown15 is offline
Old 02-14-2014, 10:11 PM
jbrown15's Avatar
Liked: 1993
Nathan,
I now have a Falcon screen and have a large 2'x2' piece of the EN4K screen material. While yes you can't see any weave because there isn't one, there is just no way I would even consider spending that much money on such a dim lack luster picture. IMHO the only advantage of the EN4K material is no visible pattern in the screen.
jbrown15 is offline
Old 02-14-2014, 10:24 PM
nathan_h's Avatar
Liked: 600
While the EN4K is low gain, it's really all about the whole equation: Got a light cannon, no problem. Got a relatively dim RS20, like me, and one has to go small in order to get reference brightness off the screen (I suspect, I haven't measured yet).
I have a sample en route to me, so I will see for myself.
jbrown15, thanks for the offer. If I like the small sample Seymour has sent, I'll hit you up for the larger sample, as well, and be happy to pay shipping.
nathan_h is offline
Old 02-14-2014, 10:55 PM
jbrown15's Avatar
Liked: 1993
It would fit into a small padded envelope so I'm sure it would only be a couple bucks. If it's less the $5 I'll send it to you for free.
jbrown15 is offline
Old 02-15-2014, 08:51 AM
nathan_h's Avatar
Liked: 600
You got mail.
Also, did you end up going with the 4k material? Your project is at least a third brighter than mine, so if you are using the 4k material I'd be curious at what size, and what the measured brightness off the screen is.
nathan_h is offline
Old 02-15-2014, 09:17 AM
archiguy's Avatar
Quoted: 3416 Post(s)
Liked: 3280
The other factor, of course, is throw distance. Lumens decrease on a logarithmic scale, if I'm not mistaken. (Been awhile since high school physics.) Twice the distance = 4 times the light dropoff. My throw is 17.5' (with a JVC 4810) so the EN4K is just not going to be enough gain. Now, I could always operate the projector on high output but the tradeoffs there are reduced lamp life and more noise from the fan running at a higher speed.
It's always a matter of tradeoffs. I've decided to go with the Falcon screen because of the higher gain. Not as smooth, but I don't think that will end up being a factor as my seating distance is 9.5' for the first row, 15.5' for the second.
archiguy is online now
Old 02-15-2014, 10:13 AM
jbrown15's Avatar
Liked: 1993
You got mail.
No I ended up going with a Falcon screen, I just couldn't live with that dim of a picture. IMO the Falcon screen is a great compromise, way brighter then the EN4K material and less noticeable then the XD material. I could see the XD material from about 9-10ft away, I have to be within 5-6ft to see the Falcon screen material. It may only be about 3ft but that's a big difference to me.
jbrown15 is offline
Old 02-15-2014, 09:42 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Gain is in itself not necessarily an advantage or disadvantage, as there is a proper application of every screen gain. While a higher gain will have brighter whites, a lower gain will have deeper blacks, better shadow detail and rejection of ambient light/reflections. If you have enough lumen output, you can compensate for lower gain, but since your projector can't suck light, it can't compensate for too high a gain.
AT screens need not have any tradeoff at all. It's what the films are mastered with and reference quality is achievable.
Cheers,
Chris
nathan_h likes this.
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
Old 02-16-2014, 10:20 AM
ADDUpstate's Avatar
Cheers,
Chris
+1
Old 02-16-2014, 10:49 AM
jbrown15's Avatar
Liked: 1993
Very true, and I agree with you Chris. And I don't feel that I'm giving up blacks or shadow detail with the Falcon screen. If I had 10k burning a hole in my pocket to buy a light cannon projector that would still give me the deep blacks of my JVC RS and another $3000+ for one of your EN4K screen that I would have gone that direct. But that's simply not the case, so I went with the next best thing IMHO.
I really did like dealing with you but I just wasn't crazy about being able to see the weave in the XD material so I had to go in a different direction.
Tom Bley and archiguy like this.
jbrown15 is offline
Old 03-21-2016, 05:37 PM
farsider3000's Avatar
Quoted: 78 Post(s)
Liked: 39
Quote:Originally Posted by nathan_h
You got mail.
It's been a few years but just wondering if you are still happy with the Falcon screen? I am moving from a Stewart Filmscreen Studiotek 100 to a AT screen but I am concerned that the AT screens will not be as sharp. I sit right at 12 ft eyes to screen.
Datasat LS10
Procella P8 LCR, Procella P5V for Atmos speakers
2.39:1 Seymour XD, 116" wide & JVC 4910 projector
Parasound Halo A31, Parasound Zonemaster 1250
JTR Captivator S2 (1st to receive New 2017 version) and Dual Seaton Submersive HP+ up front, Dual JL Audio F112 in the rear
farsider3000 is offline
Old 03-21-2016, 09:31 PM
jbrown15's Avatar
Liked: 1993
I've had fantastic luck with my Falcon screens and have loved them, I first had a 120" 16:9 screen and then went to a 125" 2.40:1 screen with the new Horizon material. We sold that house and had to leave the screen with it so in the new few months I'll be ordering a third screen from Rich at Falcon. Not only that I've had two friends buy Falcon screens after seeing how great mine looked.
jbrown15 is offline
Old 03-22-2016, 08:32 AM
nathan_h's Avatar
Liked: 600
I'm not jbrown15, and I went with the EN4k material. No complaints at all -- other than the usual one which is that now that I have a brighter projector I could have gone for a larger screen and that would be fun!
nathan_h is offline
