150" Tab Tensioned Recessed Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-27-2013, 08:21 AM - Thread Starter
hbskisurf's Avatar
I'm looking for suggestions on recessed screen options for our living room.  I'm currently using a 110" laminate screen but I'm renovating and changing around the layout of my room...so time for an upgrade.  The room is gutted at the moment so I have options on what and how to install.
Room
- 24' x 13'
- seating would be at 24'
- projector would be mounted 15' from the screen, projecting on the 13' wall
- 150" screen has to be recessed as it will cover one entrance to the room when lowered
- Lots of light in the room but the screen will be mainly used at night when it won't matter (TV will be mounted on the wall behind the screen for daytime use)
|Entry|  ------
--Screen---- |
                   |<-Window
                   |<-Window
|      Proj      |
|                  |<-Window
|   Seating   |
Projector
Purchasing a Epson 5030UB or Panasonic AE8000
Speakers
Will likely have to go with ceiling speakers as the left side of the screen will be covering the entrance (not ideal but I want a big screen...)
Questions:
1) Recessed screen or ceiling mount screen mounted on the floor joists with a slit in the drywall for the screen - can a clean recessed look be achieved without a recessed screen?
2) I've been looking at the Monoprice/Grandview, Vutec, and Elite recessed and non-recessed screens.  Are there others I should consider (tab-tensioned is a must-have)?
3) Any other general thoughts on the setup that I should be thinking about?
Thanks in advance
hbskisurf is offline
post #2 of 6 Old 12-24-2013, 09:54 AM
schuetdm's Avatar
Hey, just wondering if you got any feedback or made a purchase yet. I am also looking for something at the 150" size.
I debated the full recessed version vs installing a ceiling mounted one behind the drywall. Personally, I think you could achieve a really nice look with a drywall slit, I saw someone posted a video on YouTube who did that. I also thought if you put a vertical piece of drywall inside/up the back of the slit, you wouldn't even see a black hole while looking up at an angle.
My biggest concern though would be if you did all that nice drywall work to enclose the screen, and then down the road something needed some maintenance. Something as simple as adjusting the limits on how far the screen drops could be impossible if it gets all enclosed. You might be able to strategically place your ceiling speakers to double as access holes.
For me, I had to let the builder finish the house as is and I have to come back and cut a hole in, so I think it's just going to be easier to cut the 4 inch wide hole for the recessed screen and be done with it. I already mounted some hanger boards in the floor trusses so I have something to bolt the Monoprice style screen to.
schuetdm is offline
post #3 of 6 Old 12-30-2013, 10:49 AM - Thread Starter
hbskisurf's Avatar
I've looked around a bunch and decided to go with a recessed screen.  Since the screen is going in the living room, we really didn't want to see the slit and I couldn't find many clean looking ceiling kits that would hide the black weight bar found on most screens.
So...I'm currently leaning towards the Elite IHOME150HW2-E12 Evanesce Plus screen...although I haven't seen any reviews for it yet.  White weight bar + true flush look.
My biggest concern is tensioned vs. non-tensioned.  I have had a non-tensioned screen before that developed waves...not excited about going down that route again.
However, the tension system on most recessed screens added quite a bit of length to the case that would make the install very difficult / impossible for my setup.  Additionally several people suggested that having a tensioned screen with 2 young children in the house was probably a bad idea.
post #4 of 6 Old 08-20-2014, 09:14 PM
schuetdm's Avatar
Hey, it's been awhile, wondering if you're still around and if you got your screen yet? I'm finally getting close to pulling the trigger on this.
One thing you didn't mention was the height of your ceilings. I have a fairly large room at 20feet wide by 28feet long, but the ceiling is only 8 foot. The display area of a 150" would fit, but there would only be a few inches on the top/bottom for the border. I'm starting to think a 135" would be more appropriate, but most movies are 2:35 aspect so I'm having a hard time deciding.
I really wish I could find some ceiling recessed 2:35 aspect screens out there, but either no one makes them or I'm looking at the wrong brands. I think I'd rather have some extra screen on the sides when watching a football game, and use the hole thing for movies.
Thanks ahead of time if you got any thoughts or want to share if you're happy with your purchase.
schuetdm is offline
post #5 of 6 Old 01-28-2015, 05:15 PM - Thread Starter
hbskisurf's Avatar
I ended up ordering the Elite Evanesce Plus IHOME150HW2-E12. It is a non-tensioned screen but based on the specs and my conversations with Elite Screens, it seemed like the best bet for our application.
One important thing to be aware of is that the Evanesce Plus screen does not have the white weight bar like the rest of the Evanesce series. It won't give you a seamless look (you still see the black weight bar). A non-starter for our application.
I'm currently talking to Elite about swapping the screen for the smaller ITE135HW2-E8. It's only 135" but the seamless look is the key for our installation.
The biggest Elite Evanesce that has the 2:35 ratio is the 122" size (non-tensioned).
post #6 of 6 Old 01-28-2015, 07:04 PM
schuetdm's Avatar
Thanks for the reply. I ended up not being completely sure of the size I wanted, but I did decided I absolutely wanted 2:35 ratio. So instead of making an expensive mistake, I ended up getting a fixed frame Monoprice HD Gray Fabric (130 inch, 2.35:1) #7966 which was the right price in the mid $300's at the time.
I thought we might miss having the smaller TV for watching the news or random shows, but turns out it's just as fun to watch that stuff as it is watching movies on the projector. The TV shows have unused white space on the left and right of the screen which you quickly forget about. 130" is definitely not too big for me and I think I could even enjoy the 150" size in 2.35 aspect, however the 130" did allow room for some bookshelves and front main speakers to fit on both sides.
Now for those 4k projectors to come down in price
schuetdm is offline
Reply Screens
