Vivid Screens?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-28-2013, 08:09 AM - Thread Starter
SpineRep's Avatar
Has anyone used this screen before? I did a search and came up empty. I have a Mitsubishi HC7900-DW projector and I'm looking for an inexpensive screen to use now and then upgrade later when I can. Thanks!
http://www.a1components.com/Products/Vivid-92-in-Matte-White-Projection-Screen-with-Black-Velvet-Frame--HDTV-(16-9)__VFS392FS.aspx
SpineRep is offline
post #2 of 2 Old 11-28-2013, 08:12 AM
nickoakdl's Avatar
Quoted: 49 Post(s)
Liked: 53
If you're looking for an inexpensive screen for now look at an elite screen. They are pretty well known and people tend to be happy with them. They are also less expensive than the one you listed.
http://www.amazon.com/Elite-Screens-ER92WH1-Projection-Screen/dp/B00366MBAC/ref=sr_1_2?ie=UTF8&qid=1385651473&sr=8-2&keywords=Elite+fixed+frame
nickoakdl is offline
Reply Screens
