Jamestown White or Gray Screen for BenQ W1070? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-30-2013, 08:02 PM - Thread Starter
Dego510's Avatar
I just bought a BenQ W1070 projector and now need a screen.  I've been reading a bit about the Jamestwon screen and don't know which screen to get . . . Matte White or High Contrast Gray screen.
Any advice/suggestion is greatly appreciated!
Dego510 is offline
post #2 of 5 Old 12-01-2013, 11:22 PM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
The W1070 is a light cannon. Get a lower gain gray screen.
Skylinestar is offline
post #3 of 5 Old 12-02-2013, 06:16 AM - Thread Starter
Dego510's Avatar
Lets make it a little harder . . .
I found a used 110" Da-lite screen on craigslist for only $250 (originally $1,200).  Owner says it's in like-new condition.
Should I still go for a Jamestown grey screen or the Da-lite white screen?  Cost is about the same.
Dego510 is offline
post #4 of 5 Old 12-02-2013, 11:07 AM - Thread Starter
Dego510's Avatar
Or is a DIY better?
Dego510 is offline
post #5 of 5 Old 12-02-2013, 04:13 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The decision between white or gray has very little to do with the projector. It has everything to do with you room conditions. If you have dark walls, ceiling and floors and full ambient light control you want a white screen, a gray screen will only make your whites gray. If those conditions aren't met then a gray screen comes into play to control reflected or ambient light that hits the screen.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Reply Screens
Benq W1070 3d Ready Dlp Projector 1080p Hdtv
