Ceiling mounting solution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-13-2013, 08:25 AM - Thread Starter
kramerica2's Avatar
My current screen is a 100" 16:9 rollup screen which works perfectly fine for me. The problem is that I need to move it into a room where I'd have to mount it to the ceiling which is 9 ft. high.
The max drop I can get with the screen is 17", meaning that the bottom of my screen would be at 37" height (from the floor). I think that it's too high for comfortable viewing (from 11 ft. away), but please correct me if I'm wrong.
Is there any elegant solution without replacing the screen with a higher drop screen (that is very hard to find anyway)?
Thanks a lot for any advice...
kramerica2 is offline
post #2 of 2 Old 12-14-2013, 09:49 AM
zonecoaster1's Avatar
According to Draper, the bottom of the screen should typically be:
-24-36" above the floor if you have theatre seating or a flat floor with only one or two rows
-40-48" above the floor if you have a level floor and several rows of seats
http://www.draperinc.com/ProjectionScreens/ScreenSizeSelection.asp
zonecoaster1 is offline
Reply Screens
