Advice on buying the correct screen (details inside on proposed specs) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-23-2013, 05:31 PM - Thread Starter
CHILINVLN's Avatar
Quoted: 44 Post(s)
Liked: 36
I'm in the process of designing my home theater and I've come to realize selecting the best screen is going to be the biggest challenge.  Here are the details.
The room will be 21' long in total, and 10' wide on the end with the screen and 9' from the screen, the room will bump out to 16' wide for the final 12'.  The first row seat, your eyes will be roughly 11-12' from the screen and second row on a 12" platform will be 17-18' from the screen.  Room height is 9'.  The corner seats will have a viewing angle of approximately 30 degrees to center of the screen.  Projector, I plan to mount on the ceiling 18ft back to maximize contrast.
I plan on using an Epson 5030 projector.  The room has no windows, all decorative lighting will be on URC dimmers.
The room will ONLY be used to watch movies.  98% of the time will be Blu-Ray, rarely regular DVD, no TV.  I would like to do a 110" screen, however, I'm not entirely clear on the 16:9 to 2.35:1 ratios.  I really don't want the black bars, I want to fill the entire screen and I wouldn't mind only have those bars for regular DVD.
If anything above sounds bad, please feel free to chime in a better suggestion. :)
Questions:
1. Should I get a screen with 1.0 gain?
2. What screen do you recommend (model #) given the above specs?
3. Do I go with a 2.35:1 screen and if so, what configuration considerations do I need to keep in mind with the projector or does it auto adjust between Blu-Ray and DVD?
I appreciate the help!!
________________________________________________
Construction/Final Photos of my Custom Home Theater
http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1522794-scc-home-theatre-project-photos-complete.html
CHILINVLN is offline
post #2 of 3 Old 12-23-2013, 05:37 PM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4651
If anything above sounds bad, please feel free to chime in a better suggestion. smile.gif
Questions:
With a 5030, you need to go with a 16:9 screen. With 110" size I would go with a screen with a little bit of gain, 1.1 to 1.3. If you would like to discuss screen choices and pricing, give us a call.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 3 Old 12-23-2013, 08:57 PM - Thread Starter
CHILINVLN's Avatar
Quoted: 44 Post(s)
Liked: 36
Is there a projector with similar quality that would allow me to fill the full space on the screen for blu-ray (2.35:1) as the 5030?  Why does the 5030 not do this?
Also, can you just provide a couple options on screens in this post so that I can spend some time reading and researching them?  I don't have this opportunity over the phone.
Reply Screens
