where to purchase wall mount bracket for fixed frame screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-02-2014, 01:10 PM - Thread Starter
kgronseth's Avatar
Hi, I upgraded to a 120" fixed frame screen from a 100" screen. I bought the screen used on craigslist and it didn't come with the brackets to mount it to the wall. The ones I had for the 100" screen work fine for 120" screen so I am re-using them. I want to sell my 100" screen and would like to buy brackets to give with it when I sell it.
I am looking for the wall mount flat bracket with the little lip at the top that sticks out that the fixed screen frame hooks/attaches to. I have tried google searches and searching posts here and couldn't find the right name for that bracket or anyplace selling that particular peice of hardware.
If someone gave me the name of the bracket or a link to buy one that would be great. I'll call the manufacturer and see I can order them directly from them if necessary but would prefer something local if possible.
kgronseth is offline
post #2 of 9 Old 01-03-2014, 03:23 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Is it called a french cleat?
Sonyad is offline
post #3 of 9 Old 01-03-2014, 03:26 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
That was my first thought as well... some pictures would help people identify it for you I'm sure. Or some more info on the screen manufacturer/model...
walterappleby is offline
post #4 of 9 Old 01-03-2014, 03:37 PM - Thread Starter
kgronseth's Avatar
finally found a pic of something similar with google search. Still not sure of the name. Any thoughts? Thanks!
post #5 of 9 Old 01-03-2014, 04:59 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
What kind of material is your frame?
The Sawtooth & Ring hanger should work as long as they support(rated) the weight.
http://rachaelsscrapstore.com/shop/images/rachaels_hangeranchors_prev.jpg
2016
42Plasmaman is offline
post #6 of 9 Old 01-03-2014, 05:23 PM - Thread Starter
kgronseth's Avatar
It's aluminum covered in black velvet like material. The 100" is a Favi brand and the 120" is Elite. They both are fixed frame. The lip part of the bracket goes into a groove on the frame. I guess I figured this was a common bracket since my first screen about 10 yrs ago had the same type of hardware. (I went 4-5 years without a projector when we moved)
post #7 of 9 Old 01-04-2014, 07:52 AM
electricmanscott's Avatar
Home Depot has them
http://www.homedepot.com/p/OOK-Hangman-200-lb-French-Cleat-Picture-Hanger-with-Wall-Dog-Mounting-Screws-13-Pack-55316/202341629#
Dedicated theater
JVC RS46U
Lumagen XE3D
115"d 16:9 DIY AT Seymour XD screen with DIY masking
Marantz SR7008
Oppo BDP103
Darbee Darblet
Klipsch RF7II mains
Klipsch RC64II center
PSA XS15 Sub
Roku3
Harmony 900
electricmanscott is offline
post #8 of 9 Old 01-04-2014, 02:44 PM - Thread Starter
kgronseth's Avatar
Thanks for the help. Looks like those should work. I'll buy one and try it out.
post #9 of 9 Old 01-04-2014, 07:22 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
if you want we have some z-brackets that are used to hang our screens they are 60" long you could one and it will be plenty to support that screen. send me pm if you would like to get one
the home Depot ones may work to though but if not hit me up.
snickers1 is offline
Reply Screens
