does it exist - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2014, 12:04 PM - Thread Starter
jphorst's Avatar
Quoted: 75 Post(s)
Liked: 82
An affordable acoustic transparent screen of good quality. The first few brands I found were many thousands of dollars and kind of scared me off. I have about $1000 budget and not really interested in DIY. Iam now wondering if I should just live with the horizontal center and drop the idea of a third floor stander for a center on my budget?
I did find this one.
http://www.hd.ca/elitescreens/fixed/ezframe/acoustic/index.php
Oppo bdp-103, Denon x4200w, Emotiva xpa-5, PSA MT-110 L/C/R/SR, PSA XV15se x2, Monster Hts-3600 MKII, BenQ w1070, 92" reference 4k screen, Blue Jeans cable, Gik 242 acoustic pannels, DIY super chunk bass traps, certainteed home theater tiles.
jphorst is offline
Old 01-07-2014, 12:16 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Many people build a false wall with black AT panels and make their own AT screen with high quality AT Fabric (not sure what manufactures sell just the fabric) This is of course DIY as it is not a pull down screen and requires you to build a wall along with a screen. Unfortunately, an AT screen is not as simple to manufacture as a solid screen. It has to be color neutral, AT without causing major changes in sound, low visibility of the screen texture, good gain (holes in weave or perfs reduce are for light to refect) and then there is the moire distortion with the weave requiring it to be cut on an angle which wasted much fabric..
So if you are not finding what you are looking for at the price point you are looking, it may not exist and if it does, may not excel in all areas.. I.E. requires 14' seating distance or you will see the texture of the fabric..
Sorry this was of little help but AT = more $$ unless you DIY
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 01-08-2014, 12:39 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
Awhite bedsheet with high thread count; that's what Earl Geddes uses.
Noah
noah katz is offline
Old 01-09-2014, 08:23 AM
ss396's Avatar
Has any one tried the bed sheet method and can comment? It certainly seems easy to implement.
ss396 is offline
