Need Help Selecting Screen for Epson 6030 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2014, 11:10 AM - Thread Starter
Green79's Avatar
Sorry if i am repeating the questions  I would really appreciate if ya'all can suggest what would be good Screen choice for my configurations.
Projector: EPSON 6030UB
Rppm Size: Length 18.5 ft X 15.5 ft wide
Room type: Dedicated media room with NO windows
Type of Screen looking for : 120 " Fixed screen
Budget: $800-$1000
I tried doing my research and what i understood is if Your Projector has enough light out put (which In case of EPSON 6030UB is 2400 lumens) then it is best to go with NO GAIN. or LOW GAIN.
How high you can go on gain and still do not loose the ability to view the picture from side?
Not sure about should i go for Grey screen or white screen?
What should be the material of Screen?
Of course more money you put better product you can get in most case but i am looking in the range of $ 800 to $1000.
Pleaseeeeeeee suggest.
Thanks...
Green 79
Green79 is offline
post #2 of 3 Old 01-24-2014, 09:59 PM - Thread Starter
Green79's Avatar
Please help...!!!
Green79 is offline
post #3 of 3 Old 01-25-2014, 07:08 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
Not an expert BUT I can tell you I have a 1.3 gain screen and after upgrading to the Epson I would say this would be the max I would use... I am looking to increase the size of my screen soon and will look for something more like 1.1 as I do see a few "sparkles" in very bright scenes sometimes..my room is a little longer and narrower that yours 14 x 23
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
Reply Screens
Epson Powerlite Pro Cinema 6030ub 3d 3lcd Projector With A Pair Of 3d Glasses
