Screen Gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2014, 06:27 AM - Thread Starter
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
Can someone explain how screen gain works? I'm looking at the Stewart Cima Tiburon, with .95 gain, and the Cima Neve with 1.1 gain. So will the Neve be 15% brighter? My screen will be on the small side (100" diag.) and I'm wondering if it's better to go with the Neve because of it's slightly higher gain, even though I have a light colored ceiling. Proj. will have 1700 lumens & my throw is about 11.5 feet.
TL5 is online now
post #2 of 5 Old 01-29-2014, 06:30 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
here is good explanation
http://www.projectorcentral.com/projector_screens_gain.htm
snickers1 is offline
post #3 of 5 Old 01-29-2014, 06:52 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
A gain of one is about that of a piece of computer paper. .95 is not much different,neither is 1.1
With 100" screen and less that 12' projector distance and 1700 lumen you are splitting hairs and the screen will be very bright.
The more important thing is screen texture and hot spotting will either it be visible from you seating distance?
Buy the projector first, order free screen fabric samples from the vendors and test them.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 5 Old 01-29-2014, 10:37 AM
Mike Garrett's Avatar
Quoted: 5590 Post(s)
Liked: 3578
What projector are you planning on using?
mjgarrett100@gmail.com
Mike Garrett is online now
post #5 of 5 Old 01-29-2014, 02:52 PM - Thread Starter
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
Either a Sony HW55Es or (if I can swing it)... 600ES. I know if I go with the Tiburon screen it'll be really bright for 2D, I'm concerned about 3D brightness.
TL5 is online now
Reply Screens
