Will a Da Lite HP screen work for me? Should I replace my Carada BW? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-05-2014, 05:28 PM - Thread Starter
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
I've decided to get an HP screen for 3D. I'm getting a Mits 7900 for just 3D and I'm gonna just use it on a stand when I watch 3D so I can get the projector at around eye level.
I also own the JVC RS4910. This projector is ceiling mounted at a height of 6.5 feet and is 12 feet away from the screen. The screen is very close to the ceiling and the top of the screen is about a foot higher then the projection lens.
Can I still use the HP screen with my JVC without getting serious issues? How much gain would I still get with my ceiling mounted JVC? Would there be serious hotspotting, or colour shifting or UNEVEN brightness uniformity with the HP and JVC?
I'd rather have 1 screen and just get a fixed frame HP screen and replace my Carada BW screen. I can also get a manual pull down HP screen and just run two screens. HP for 3D and Carada for the JVC.
Would the HP be beneficial or at least equal to the Carada in my setup? Even without the added gain, I'd be fine with the HP and JVC as long as their was no issues with screen uniformity.
conan48 is offline
post #2 of 10 Old 02-05-2014, 05:44 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
You won't get any gain, it will be about a standard gain of 1. After you set up your 3D projector, use it on 2D and I am going to bet you find a way to lower the JVC
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 10 Old 02-06-2014, 06:35 AM - Thread Starter
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Will there be issues with the image though? I don't mind a 1.0 gain but not if the image is non uniform, uneven colours across the screen, etc. How would the HP with only 1.0 gain compare to the Carada?
conan48 is offline
post #4 of 10 Old 02-06-2014, 07:09 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
I have no idea, if I were you,I would order a free sample kit from Dalite and put them up on your current screen to get an idea. You will not see uniformity issues with the HP but still check out the samples.
Doug
post #5 of 10 Old 02-06-2014, 11:43 AM - Thread Starter
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
unfortunately a 8 x 10 sample won't help me with that. So uniformity should still be fine even though it's not getting any gain. Just don't want the top half of the screen to be brighter then the bottom half for examnple.
conan48 is offline
post #6 of 10 Old 02-06-2014, 11:51 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Uniformity will not be an issue. You could however order 6 or 8 samples of HP fabric and place equally around the screen for you own piece of mind.
Doug
post #7 of 10 Old 02-06-2014, 12:20 PM - Thread Starter
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Thats true. I wonder if they will send me that many samples. LOL, Maybe if I get enough samples I can patch together a screen for myself.
You seem confident that uniformity won't be an issue, So I'll take your word for it. It would be nice for someone else to confirm. Thanks.
conan48 is offline
post #8 of 10 Old 02-06-2014, 01:12 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
The bigger question brought up on your cross post which I had assumed you already verified is that the projector need a good amount of lens shift to be placed at center screen. Your whole purpose goes out the window if you new projector can not be set up correctly.
Doug
post #9 of 10 Old 02-06-2014, 02:42 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
He hasn't given enough info to say that.
My pj is 7 ft from the floor and I get 1.8, though it's a lot farther back.
conan, you need to punch your setup data into Flaboy's screen gain calculator.
Noah
noah katz is offline
post #10 of 10 Old 02-11-2014, 01:15 PM
roxiedog13's Avatar
Quoted: 1297 Post(s)
Liked: 544
That is what I was going to suggest. Go to the search bar above and type in All Screen Gain Calculator .
I have tried the HP samples with a PJ mounted in the same relative position as you have suggested. , 10 inchs below the top of my screen. Even at 13.5 feet from the screen my Sony VPL VW500ES makes some serious gain
from the HP, certaily more than my 1.37 gain SOlar 4K.
BTW, you can get the HP from Elune Vision in Canada. They call it Cinema Pro 4K I believe. It is exactly the same, has no hot spotting but does have a predictable off axis loss that is not dramatic. IMHO the HP is one of the better choices
for 3D if you can set it up properly.
Dedicated Theater: Sony VPL VW 675ESB & JVC X950RU/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
Reply Screens
