screen for benq w1500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-17-2014, 03:12 PM - Thread Starter
swenjj's Avatar
I have been all over the map choosing a projector.hard to do without seeing them.decided on the 1500. Kind of in the middle of my choices. I have a total light control man cave.the end with the screen on is only 9'9" wide.room is 25 long.just widens out halfway. I plan on setting up the projector and seeing the image before I decide on screen size.and screen size will make my speaker choice easier to see. My room is dark the ceiling is white. at least for now. I'll be using the screen pretty much 100% for blu-ray movies.and using 3d when kids visit. Budget is tough to say.is a $1000 screen 5 times better than a 200? If I have a $ 500 budget can that work? Are they easy to mount? I want fixed frame
swenjj is offline
post #2 of 4 Old 02-18-2014, 02:45 PM - Thread Starter
swenjj's Avatar
Visual apex off Amazon ok? For the benq would I use a white screen? Any gain?
swenjj is offline
post #3 of 4 Old 02-25-2014, 07:01 PM - Thread Starter
swenjj's Avatar
Since my thread was dead I ordered a 100" elite screen off amazon. Hope that works out
swenjj is offline
post #4 of 4 Old 02-27-2014, 03:30 PM - Thread Starter
swenjj's Avatar
http://www.amazon.com/gp/aw/d/B00366KE3I
Anyone have that screen with a 1500? Or any dlp
swenjj is offline
Reply Screens
Benq W1500 1080p Hd Wireless Dlp Home Theater Projector Silver
