Recreating IMAX immersion at home - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Dave in Green
post #1 of 13 Old 04-24-2014, 11:06 AM - Thread Starter
drjay71's Avatar
Quoted: 68 Post(s)
Liked: 35
I had a few questions about IMAX and how one could go about recreating the immersive experience of IMAX at home. I know to truly get the IMAX experience we are talking about a VERY expensive proposition. I am just referring to the screen size, viewing distance, and angles to get something similar to IMAX with respect to immersion. I understand IMAX is much closer to a 16:9 ration screen rather than a 2.35:1 screen. What is the maximum and minimum viewing angle? Not just horizontal but vertical. For example, my room is 14'4" wide by 19' deep by 10' tall. What size 16:9 screen should I be considering if my seat to screen distance is 14' and the screen would go on the 14'4" wall?
drjay71 is offline
post #2 of 13 Old 04-24-2014, 12:01 PM - Thread Starter
drjay71's Avatar
Quoted: 68 Post(s)
Liked: 35
Interesting videos on YouTube
https://www.youtube.com/watch?v=NOqAl-HEIis
drjay71 is offline
post #3 of 13 Old 04-24-2014, 04:45 PM
dragonleepenn's Avatar
Quoted: 193 Post(s)
Liked: 85
I have been thinking about this a lot lately. I would like a IMAX looking front screen in my hometheater. I currently have a 10'5 wide 235.1 Seymour center stage screen and love it, however I want to go 12' wide. I can't decide if I should go with a 16x9 aspect ratio for that huge look in my room (constant) width, or stay in the 235.1 ratio at a 12'width. Both would increase the screen height. Anyone with thoughts please chime in.smile.gif
drjay71,
Thanks for posting this as I was about to start a thread and may as we'll learn about it here on your thread.biggrin.gif
I sit 14'5" back from my current screen at the main listening position, when I change to the 12' width screen I will not change that distance it will remain.
On your setup you can go 12' wide with a16x9 ratio, you got the ceiling height and width for it.
Make sure you take into account how close you sit the size may overwhelm viewers.rolleyes.gif
PeterV
dragonleepenn is offline
post #4 of 13 Old 04-24-2014, 05:33 PM - Thread Starter
drjay71's Avatar
Quoted: 68 Post(s)
Liked: 35
drjay71,
PeterV
That is the one thing I would worry about if I went this route. I don't want to overwhelm viewers especially when it comes to vertical viewing angle as this can be quite fatiguing and even nauseating. There is a fine line between full immersion and being overwhelmed
drjay71 is offline
post #5 of 13 Old 04-24-2014, 06:17 PM
R Harkness's Avatar
Quoted: 1927 Post(s)
Liked: 1627
It's kind of funny: those videos start off with a goal of replicating the IMAX experience via viewing angles etc, and then it's "Naaah, let's not really" and ends up with a regular ol' home theater approach for the screen/viewing distance.
R Harkness is online now
post #6 of 13 Old 04-24-2014, 06:18 PM
R Harkness's Avatar
Liked: 1627
That's one benefit I've found of going with a Variable Size Image system (multiple masking). Images can be made IMAX-like for the appropriate content, and dialed back for other stuff, or depending on the viewer's aptitude.
post #7 of 13 Old 04-24-2014, 06:42 PM
Quoted: 193 Post(s)
Liked: 85
This is my screen/front end.
PeterV
post #8 of 13 Old 04-25-2014, 11:49 AM
Mike Garrett's Avatar
Quoted: 5556 Post(s)
Liked: 3540
I agree. My screen is a curved scope screen with 54 degree viewing angle. I use high output (DIY) speakers for the front three and actual JBL Pro surround speakers. Use multiple subs and a lot of amplification, but I don't try to call my system an IMAX system.
mjgarrett100@gmail.com
Mike Garrett is online now
post #9 of 13 Old 05-11-2014, 09:17 AM
MrsMiniver's Avatar
Great questions! I love going to see IMAX movies be it digital or film.
As to your question:
1. IMAX field of view should be 60' to 120' lateral field of view and 40' to 80' vertical field of view. This would be for a real, purpose built IMAX venue. In other words, the screen image should fit your peripheral field of vision.
2. You sound system needs to have a decent power to each channel. Anything above 100W for a small room would work.
3. Make sure you are running 5.1
4. Reveb time if you are into that type of thing must be between .5 - .7 sec.
5. Low frequency should be set between 20-80 Hz
6. Rear speaker placement should be set up like an IMAX theatre, you should use dipole speakers if you can. The speakers should hung at the rear corner of the room and pointed down.
That is about it. Most important and this is documented in IMAX technical documents is the viewing angles and your relation to the screen.
MrsMiniver is offline
post #10 of 13 Old 06-21-2015, 10:52 AM
jogiba's Avatar
Quoted: 511 Post(s)
Liked: 234
IMAX threatens Ars Technica for saying IMAX !
IMAX threatens Ars Technica for saying VR is like 'IMAX in your house'
http://www.tweaktown.com/news/46011/...use/index.html
jogiba is offline
post #11 of 13 Old 06-22-2015, 04:49 AM
Frank714's Avatar
Quoted: 462 Post(s)
Liked: 195
Originally Posted by jogiba View Post
Ah...IMAX has taken back its request. Frankly, I can understand the first reaction.
Considering the industry's abuse of "home theater" (correct: home video for flat screen environments, IMHO), which used to be synonymous for projection screen environments, actual "home theater" descriptions (indicating the use of a larger projection screen) now resort to the use of "IMAX" to indicate a home theater with projection and larger screens.
Of course, any home theater is merely a shadow of an actual IMAX theater. Program content has been reformatted from 1.33:1 to 1.78:1 on Blu-ray, and I'd still love to see a home theater recreation of an OMNIMAX dome.
Hubble 3D has some breathtaking images of the Hubble space telescope, but unfortunately these are best suited for spherical OMNIMAX projection.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #12 of 13 Old 06-22-2015, 09:15 AM
Dave in Green's Avatar
Quoted: 1283 Post(s)
Liked: 853
I read Ars Technica daily and followed this story as it was happening. The original use was entirely appropriate within the context of how it was worded and the IMAX legal department clearly overreacted. When confronted, IMAX quickly realized its mistake and appropriately apologized. Maybe IMAX is following the path Bose started down in 1970 when it sued Consumer Reports over its lukewarm review of the original Bose 901 speaker. Bose has remained aggressively litigious right on through their 2014 lawsuit against Apple's Beats.
DavidHir likes this.
Dave in Green is offline
post #13 of 13 Old 06-30-2015, 01:35 PM
Liked: 0
Great info guys, thanks for sharing!
jmblock22 is offline
Reply Screens
