Elite CineWhite or CineGrey for Epson 3020 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-01-2014, 11:19 AM - Thread Starter
acousjim's Avatar
I'm going back and forth between these two materials. The room has white ceilings(7'6") and the walls are a sand color. This is in the basement, so I can control the ambient light. But I don’t want to always have all the lights off just to use the projector. Any suggestions? Thanks
acousjim is offline
post #2 of 3 Old 05-01-2014, 03:52 PM
nightfly85's Avatar
Quoted: 72 Post(s)
Liked: 43
Could be wrong but I thought the grey screens are for DLP projectors - to help their contrast out as they tend to have plenty of brightness.
Outside of that, if that PJ is contrast challenged, then go for the grey and you'll also get a drop in brightness (neg gain). In most cases folks prefer positive gain screens.
FWIW
nightfly85 is offline
post #3 of 3 Old 05-01-2014, 05:13 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 170
Get the Cinegrey 5D. I fell for all that talk that grey screens are no longer needed because modern projectors have such great contrast. Don't fall for it the way i did. Unless you have dark walls and a dark ceiling, the room will compromise your contrast. The Epson 3020 has good, not great, contrast. It needs help from a good screen to perform its best. The Cinegrey 5D will help preserve the 3020's contrast even with some ambient light, and will give you greater brightness with its 1.5 gain.
ben38 is offline
Reply Screens
