Tab-Tensioned, how tight is enough? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-06-2014, 11:25 AM - Thread Starter
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
I've got a 106" Elunevision Titan that has developed some slight waves, not enough to be visible with a movie on but on an all white screen I can see them.
How tight should I have the tensioning strings? Right now there is quite a bit of slack on them and it doesn't seem the adjustments will get them any tighter. I can pull the strings until they are quite taught (enough to make a higher pitched note when plucked) and the waves lessen, is that how they are supposed to be and my adjustment knob is just broken or should they be reasonably loose?
Thrillho is offline
Reply Screens
