Put center channel speaker behind regular screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-08-2014, 06:14 AM - Thread Starter
soupcxan's Avatar
Quoted: 27 Post(s)
I have a 120" elite screen. It's not acoustically transparent. How bad would it be to put my center channel speaker behind the screen? I've run out of space to put it in front of the screen. Or should I mount it on the ceiling and have it face downward toward the seats?
soupcxan is offline
post #2 of 11 Old 05-08-2014, 10:53 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Only if If you want everything to sound like the adults on the Peanuts biggrin.gif
Sorry this would be a very bad idea.
Craig Peer likes this.
trans_lux is offline
post #3 of 11 Old 05-10-2014, 04:47 PM
Audiojan's Avatar
Quoted: 18 Post(s)
It'll be bad… the sound will change to the point where you'll notice a major disconnect between L/R and center. I would highly recommend getting an AT screen (or my not just the screen material from Elite?!)
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #4 of 11 Old 05-15-2014, 12:32 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3042 Post(s)
Liked: 2975
I have my center channel speaker mounted right above my screens, angling downwards. I works fine. You might try that.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #5 of 11 Old 05-17-2014, 07:22 PM - Thread Starter
soupcxan's Avatar
Quoted: 27 Post(s)
I tried the center channel speaker behind the screen and it sounds muffled. Will have to mount it above the screen.
soupcxan is offline
post #6 of 11 Old 05-18-2014, 08:17 AM
Audiojan's Avatar
Quoted: 18 Post(s)
What kind of screen do you have? Maybe you can replace the material with AT material instead? Would be much better than mounting the center too high and angle it down...
Audiojan is offline
post #7 of 11 Old 05-19-2014, 08:30 AM - Thread Starter
soupcxan's Avatar
Quoted: 27 Post(s)
What is the best mounting solution to hang a center channel speaker from the ceiling? Because the screen is at a 45' angle in a corner, I don't have a wall directly behind the screen to mount a shelf on.
soupcxan is offline
post #8 of 11 Old 05-19-2014, 09:44 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2975
That is an interesting problem. My center channel speaker uses a wall mount that screws to the speaker. You might need a corner shelf, or bridge the corner with a piece of lumber, finished to match the screen frame ( black velvet? ).
post #9 of 11 Old 05-19-2014, 12:49 PM
Mike Garrett's Avatar
Quoted: 5588 Post(s)
Liked: 3569
What size speaker? Several options:
1. use a flat panel articulating arm mount.
2. If the ceiling is close, you can use a speaker mount, off of the ceiling.
3. Bridge the corner with blocking. Place blocking flush with top of the screen. Build angled shelf on top of blocking. Place speaker on shelf. You could also hang the screen off of this blocking.
mjgarrett100@gmail.com
Mike Garrett is online now
post #10 of 11 Old 05-19-2014, 06:26 PM
dan30306's Avatar
I mounted a B&W CM Centre 2 over a fire place. That is a huge center (and heavy) so I used an old school tube TV wall mount. Worked well and it held the weight. They come with straps so you can use that to secure the speaker on the stand if you need to point it downward. Plus, it was cheap for the mount.
dan30306 is offline
post #11 of 11 Old 05-20-2014, 04:06 AM
KCAC's Avatar
I just mounted a Da-Lite electric screen over a center channel and my front channels, I custom ordered and added an acoustic perforated drop to clear the speakers,  I can partially raise the screen so the screen covers the speakers, it makes a huge difference and the sound is not at all clear even if turned up.  They do make a perforated screen but I would think you would then lose picture quality. I would try the speaker on the ceiling as well as below the screen if possible to see the difference. You could always go to a high quality small speaker like a Bose, I have used a Bose 5.1 system in the past all ceiling mounted and they are pretty amazing for being so small and the wife likes that they are so small so not very noticeable., Consumer Reports rates a small Samsung speaker higher than the Bose, but it is all in the ear of listener..
KCAC is offline
Reply Screens
