painting projector screen - AVS Forum
post #1 of 4 Old 05-15-2014, 08:56 PM - Thread Starter
sleepwalker3's Avatar
using high gain screen paint, should the paint be sprayed on or brushed?
sleepwalker3 is offline
post #2 of 4 Old 05-15-2014, 09:19 PM
ben38's Avatar
Quoted: 107 Post(s)
Liked: 68
Spray paint if you're good at it. If you can't spray, use a roller.
ben38 is online now
post #3 of 4 Old 05-15-2014, 09:48 PM - Thread Starter
is grey paint ok or should it definitely be white if i'm looking to get the most brightness out of a high gain screen? with grey significantly reduce the brightness?
post #4 of 4 Old 05-15-2014, 10:10 PM
ben38's Avatar
Quoted: 107 Post(s)
Liked: 68
I'm a painting neophite. You should go to the DIY screen forums. MississippiMan is the big expert over there.
ben38 is online now
Reply Screens
User Tag List
