Projector screens sound transparent under $1000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-13-2014, 07:49 PM - Thread Starter
gowingsgo1974's Avatar
Dedicated theater, looking for around 120" inch screen, are there any under $1000 that are sound transparent?
Was looking at the Carada Criterion series but I am not sure that is sound transparent.
Thanks in advance for your help!
gowingsgo1974 is offline
post #2 of 2 Old 07-13-2014, 10:18 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Go to Jamestown home theater. A 120 inch screen with Seymour CenterstageXD material can be had for 525 dollars. The wait times can be anywhere from 3 weeks to two months.
If you don't want to wait, you can buy material from Seymour and build a frame.
ben38 is offline
Reply Screens
