Silverticket 120" matte gray screen $300 - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2014, 10:34 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Has anyone here had any experience with Silverticket's matte gray screen? The price is enticing, but I'm curious how it would perform next to a screen like the cinegray 5d.
Link http://www.amazon.com/STR-169120-G-S...jection+screen
joedeeze is offline
Old 07-19-2014, 02:47 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Looks just like the regular Elite Cinegrey material.(Not Angular reflective) No way will it be as bright as the Cinegrey 5D, but brightness uniformity should be better.
ben38 is offline
Old 07-19-2014, 04:58 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Thank you for the reply. I made post a few days ago about painting my wall gray, but I came across the silverticket and it looked like a great deal.
Any chance you might be able to help me with my screen choice?
In a nutshell I'm just really having a tough time figuring out what approach to take.
I want to be able to play some games and watch movies in my room with some ambient light, and I'd also like a boost to contrast. If a little brightness is lost I would be okay with it.
How much brightness would you estimate would be lost if I used the silverticket screen rather than a white one, projecting from 13 feet away with a benq w1070? Do you think I would have improved contrast and be able to watch with some ambient light? Is some brightness the only thing that is lost? Also, picture uniformity is important to me.
The room I'll be using is not a dedicated theater and I will have a sliding door off to the left of the screen, but no windows other than that. The walls and ceilings are off white.
I should mention that this is my first projector and this will be my first screen. I'd be willing to pay up to $500 for the screen if it makes a huge difference. Looking for 120"
Thank you!
joedeeze is offline
Old 07-20-2014, 04:00 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Thank you!
With a bright room like you're describing , Joe, there are trade-offs involved. Before we get to screens, Let's talk about your projector.
The projector you're planning on using (Benq w1070) has phenomenal light output in every mode, (1700 plus lumens in Normal lamp, 1300 plus lumens in Eco) which is a great starting off point. Lots of projectors make claims of high light output, but those are usually in their highest Dynamic modes which give up color accuracy in return for more light. When asked to put out in more natural color modes, they always fall way short of the Benq1070. The Only Home theater projector I know of that can put out as much light as the Benq1070 in all its modes is the Sony hw40es at about 2.5 times the price. The Panasonic ae-8000 is even brighter in some modes, but at 2.5 to 3 times the price. So, really you have the best bang for the buck with the Benq1070.
The reason I'm talking so much about the Benq's light output is because, with such a bright projector, you should first see how much of an ambient light problem you have before you start thinking about what screen to use. My advise to you, Joe, as a first time projector user, is to set up your projector and project it on your bare white walls. The Results may happily surprise you. Or at the very least, give you a much more accurate idea of what direction you want to go in terms of what screen to use. Good Luck, and report back your results. Then We'll talk about screens.
ben38 is offline
Old 07-21-2014, 07:16 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Ben,
Thanks for the input! I'm moving into a new condo in a week and a half, so I'll set up the projector and check it out when I get there. Right now I'm projecting on a grayish/green wall and can't believe how good the 1070 looks on such a sub-optimal surface. My new walls are off-white so that will give me a good understanding of what the projector will look like on a white screen.
My question to you is this - what I'm I looking for when I test out the projector on the wall? How will I know what type of screen to get?
Also, is it normal to see more clarity in the projector when I go from 135" to 120"? I've been playing some PS4 on it and it seems like it looks much better at 120 than 135. Just wondering if this is normal.
Thanks for all the help!!!
joedeeze is offline
Old 07-22-2014, 05:20 AM
Quoted: 66 Post(s)
The smaller you make the pic the better it will look. Thats the trade off. So you need to find what you will be happy with. Your screen gaim will help determine this. I find 120in to 125in to be about the largest I like with a average gain of 1.3 and a average projector
hotpepper007 is offline
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Ben,
What you're looking for is a picture that is satisfyingly bright, sharp, and with good contrast in a room with bright walls. If you're not happy, then you start looking to ideally darken your room. If that's not an option, then it's time to look at specialty screens.
The room you're projecting in now, if all the walls are grayish green as you say, then you have walls with a reflectivity rating probably in the low to mid 30's, which is why your picture looks pretty good. When you move into the white room, your reflectivity rating will be 100 or very close to 100. (Black is 0, White is 100) This much reflectivity will surely wash out your picture. To what degree of washing out you can live with is up to you.
ben38 is offline
Old 07-22-2014, 07:55 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Sorry, Joe. Got called away before i could finish.
Yes. A 120 inch picture will look clearer than a 135 inch picture because the projector can concentrate more light on the smaller screen. Also, if your projector is in a fixed position, and you are zooming the picture to vary the size, the 120 inch picture may also have better focus because you're moving the lens more to the center of its zoom range. (Where lenses are at their sharpest) When you increase the size, you're moving the lens to the limit of its range. (Where sharpness and brightness start to fall off)
ben38 is offline
Old 07-24-2014, 07:50 PM
Liked: 0
you are right,i agree with you,Yes. A 120 inch picture will look clearer than a 135 inch picture because the projector can concentrate more light on the smaller screen. Also, if your projector is in a fixed position, and you are zooming the picture to vary the size, the 120 inch picture may also have better focus because you're moving [IMG]http://*******/WNKpGN[/IMG]the lens more to the center of its zoom range. thanks
yenturewite is offline
Old 07-30-2014, 01:55 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Just wanted to follow up on this thread. I found my picture was washed out in my new place so I purchased this screen. Will be setting it up tomorrow and I'll post my impressions if anyone is curious.
joedeeze is offline
Old 07-31-2014, 08:55 AM
g_bartman's Avatar
Quoted: 143 Post(s)
Liked: 122
Yes, I'm curious. I will be moving into a new construction house with a dedicated theater. I'm looking at that screen for an Optoma dlp projector.
g_bartman is offline
Old 07-31-2014, 10:07 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
For a dedicated theater room, you wont need a grey screen. A low gain white screen is all your Optoma projector will need for a bright, uniform picture.
ben38 is offline
Old 08-01-2014, 12:23 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1763 Post(s)
Liked: 806
That would depend upon the model Optoma. Many models have low contrast and sub-Theater Quality Black levels. Brightness does not always equate to a balanced image, and all too often can detract from other very important aspects of a image's appearance. Add in a White surface and basically you can get a negative result...on in the least a diminishing return.
To witt:
Oft times a light Neutral Gray surface can radically improve perceived contrast without overtly affecting White balance and dynamic color rendition. In fact, a light Gray can enhance Color depth and saturation, as well and improve subtle shadow detail that gets lost on a White screen.
Certainly some PJs with uber Contrast specs can get by quite nicely with a 1.0 gain Matte White. However there are only a very few Optomas that come close to really qualifying for that honor.
I like Bright Optoma s, brook no mistake....but I often mitigate their lack of Contrast by employing a Gray surface. Sometimes a bight PJ set on Economy output and hitting a Gray surface results in the absolute best of both worlds.
MississippiMan is offline
