Motorized Stewart screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-28-2014, 02:59 AM - Thread Starter
cam
cam's Avatar
I will be migrating to LA early next year, and is thinking of getting a Stewart electric roller screen (currently using a fixed 16:9 Firehawk G2 100" screen).
Where should I shop for the new screen, right here with AVS Science ? Or there are many competitive dealers out there ?
What % discount will I get off the MSRP normally for Stewart ?
Thx for any information,
Cam
cam is offline
post #2 of 7 Old 07-28-2014, 06:50 AM
kimg1453's Avatar
Quoted: 41 Post(s)
Liked: 90
Cam
Cam,
Contact AVS as they will work with you and provide the best price. Actual discount prices can not be discussed on the Forum.
Good Luck!
kimg1453 is offline
post #3 of 7 Old 07-28-2014, 08:55 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4023 Post(s)
Liked: 4077
Cam
Give us a call or email. We'd be glad to help.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4 of 7 Old 07-28-2014, 06:31 PM - Thread Starter
cam
cam's Avatar
Originally Posted by kimg1453 View Post
Cam,
Good Luck!
Thanks for the info.
cam is offline
post #5 of 7 Old 07-28-2014, 06:35 PM - Thread Starter
cam
cam's Avatar
Sure, will do after I get the details sorted out. Thx.
cam is offline
post #6 of 7 Old 07-29-2014, 12:23 AM - Thread Starter
cam
cam's Avatar
BTW, I have roughly calculated that for a 92" 16x9 screen, sitting about 10' away, the angle to the screen edge is about 23 degree, so Firehawk (with half gain at 30 degree) is probably no longer suitable, should I go for the Greyhawk or StudioTek 130 ?
I just worry about Greyhawk's 0.9 gain, even though I have a pretty bright Sony VW500/600
Thanks for any suggestion.
cam is offline
post #7 of 7 Old 07-29-2014, 05:46 AM
kimg1453's Avatar
Quoted: 41 Post(s)
Liked: 90
Cam,
Give Craig or Mike at AVS a call and they can advise the best fit for your application. A lot will depend on whether you room will have light control or not among other things in determining the best material.
kimg1453 is offline
Reply Screens
