What's the best Da-Lite screen if people 20-30 feet back need to read text? - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2014, 04:22 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
I'm looking at Da-Lite high contrast matte screens. I'm curious which ones would be best for reading text from far away in mid-high ambient light rooms?
vangeliss is offline
Old 08-06-2014, 09:12 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
What you're asking about is difficult to accomplish with front projection, at least if you care about picture quality. I don't believe that Da-Lite makes any good ambient light rejection screens. You should be looking at SI's Black Diamond or a DNP Supernova for that application.
You'd get better results using an 80" - 90" LCD TV as your display. Sharp & Visio have a few models in that size category.
henrich3 is offline
Old 08-07-2014, 04:57 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
For what purpose do you want this screen for? It sounds like you're looking to read text in either a buisness room or education room environment. In that case you'll be better served by a white board and an ultra short throw projector.
ben38 is offline
Old 08-07-2014, 02:51 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
The current plan is for a 133" screen, and one of these projectors -
http://www.projectorcentral.com/BenQ-SH940.htm
http://www.projectorcentral.com/Sony-VPL-FH31W.htm
http://www.projectorcentral.com/Optoma-EH501.htm
http://www.projectorcentral.com/Panasonic-PT-AR100U.htm
Old 08-07-2014, 02:52 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
We'll be doing tech meetups, watching movies, so 20-30 people in the room. Text, video etc..
Old 08-07-2014, 05:26 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
Your first three picks are definitely light canons and should do well for your application. You might want to drop the Panny.
The Supernova 08-85 and Black Diamond .8 are tops at rejecting ambient light. The Supernova has fewer picture artifacts (hotspotting, sparklies) than the BD. Those are both expensive specialty screens however. If you need something less pricey, a basic dark grey material may suffice. Da-Lite's darkest is their HD Progressive 0.6.
You might want to contact one of the AV Science store reps to get their recommendations.
henrich3 is offline
Old 08-07-2014, 07:51 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
The First three are true Data projectors that can also be used for movies. The Panasonic is a Home theater projector that can be used for data if need be. It depends on what application you think you'll be using the projector the most for.
The Benq and the Optoma both use DLP technology. If some of the viewers in your group are RBE sensitive, you might want to consider dropping these two.
That Leaves the Sony and the Panasonic. The Sony will do Data better, the Panasonic will do movies better. Again it depends on what you will use more.
As for what screen to use. I'd probably just stay with a regular white screen, because with a big crowd of viewers I would want to have the widest viewing cone possible with the least amount of artifacts. (Sparkles and Hotspots.) Just turn the lights down when it's movie time.
ben38 is offline
Old 08-07-2014, 08:46 PM
Archaea's Avatar
Quoted: 2840 Post(s)
Liked: 2420
Resolution and text size will have more to do with whether the people that far away can see it or not. 720P will be more effective for a desktop viewability than 1080p from that distance if you are working within Microsoft products.
Archaea is online now
Old 08-08-2014, 12:25 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
Power points too?
Is there a happy medium between power point readability, and movie/game watching?
vangeliss's Avatar
Quoted: 23 Post(s)
Are we better off getting a large LCD TV?
Old 08-08-2014, 12:26 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
Do they come in electric retractable recessed ceiling versions?
Old 08-08-2014, 01:51 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
If you don't mind keeping your screen size to 90 inches or less, a large tv is an option. A 130+ inch tv is impractically expensive. If you can audition projectors at a store, that would be the best way to see which projector will work for you or not.
ben38 is offline
Old 08-08-2014, 03:21 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
Is there a medium between the Pan and Sony? We'll be doing presentations more than entertainment, but I don't want videos/games to look like crap.(it will be viewed from 10-20 ft.)
Old 08-08-2014, 04:18 PM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 168
Data projectors are built for light output. They'll play games as well, but probably not very well. The Sony hw40es is great for games but may look a little dim with a lot of light in the room. Seems like everything is a tradeoff. You might want to have two projectors. A bright 720p projector for data, and the Sony hw40es for games and movies.
ben38 is offline
Old 08-08-2014, 06:49 PM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
So our main priority is Text readability. With that being the case, what's your top 3 picks? The room in total is about 52'x30'. We will have people watching the 120"-130" screen from up to 30' back.
Old 08-12-2014, 09:57 AM - Thread Starter
vangeliss's Avatar
Quoted: 23 Post(s)
Is there a Resolution/Text size projector you can recommend?
