120" or 133" fixed screen?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-08-2014, 04:13 PM - Thread Starter
udtsealeod's Avatar
120" or 133" fixed screen, what should I buy?? Sony 55ES projector, on a Dragonfly or SI Slate screen. HT 25'x15'x9' part of a 64'x15'x9' rec room. Controlled ambient light for movies (black pit) and controlled recess lighting for DirecTV sports while playing pool, shuffleboard or air hockey. Why not the 133" vice the 120"??
FREEDOM ISN'T FREE
USN, CDR, RET
UDT/SEAL-EOD 1971-2003
udtsealeod is offline
post #2 of 2 Old 08-08-2014, 07:46 PM
gibroni's Avatar
Quoted: 20 Post(s)
Depends on your seating distance and the screen ratio you intend to go with. There's a chart that shows you the recommended viewing angles.
gibroni is offline
Reply Screens
