Which Screen Please Help - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Craig Peer
post #1 of 7 Old 08-27-2014, 02:48 PM - Thread Starter
realestatecody's Avatar
I'm looking to purchase my first screen, I'm looking at a 110" screen the room has zero natural light so glare is not an issue. I am not looking for an AT screen either, wanting a fixed screen budget is around $1,000 plus or minus a few hundred. Heard good things about Draper screens any other ideas?
realestatecody is offline
post #2 of 7 Old 08-27-2014, 06:07 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
What color are your walls and floor?
Carada might be an option, but depends on how much brightness you need as they are lower gain screens.
DavidHir is offline
post #3 of 7 Old 08-28-2014, 01:07 PM - Thread Starter
walls are black, carpet is a real dark brown
post #4 of 7 Old 08-29-2014, 09:51 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2970
Stewart Cima Neve is another option. Da Lite HD Pro 1.1 also. Screen Innovations Solar White too. Give us a call at AV Science for prices and advice / help. I've had personally built home theaters ( on my 3rd theater ) myself for over 12 years.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #5 of 7 Old 09-04-2014, 07:39 PM
Ftoast's Avatar
Quoted: 1919 Post(s)
Liked: 624
That sounds like a mighty fine room that would pair exceptionally well with any number of low gain, smooth white fixed-frame screens.
There's no particular reason to spend a lot of money for a simple solid white screen, though. The only thing you need to worry about avoiding is added gain or texture. It can be very hard to tell without reviews whether or not a screen will be textured or smooth.
The only thing any particular brand should be able to add to the equation is a more robust or easily assembled frame.
This is also the easiest circumstance to simply paint and frame-off a section of wall if you felt like going that route instead. The white pigment in simple flat interior wallpaint is one of the most perfect screen-surfaces you'll be able to find. If your wall is reasonably smooth, you can just tape off an area, roll on two coats with a 1/4" roller, pull the tape and set a frame.
The performance alone is worth it if at all possible. The price just adds the best imaginable cherry on top.
The $1000 can then go into the replacement lamp budget or count toward the future upgrade fund.
You'd also do well to darken the ceiling if it isn't already. In a room that dark, even a middle grey shade will look surprisingly bright on the ceiling.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #6 of 7 Old 09-05-2014, 02:20 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2970
Sorry - I have 20+ years in commercial construction, a lot of it doing smooth wall drywall in commercial kitchens. It would be extremely difficult to get a wall as smooth and uniform as a Stewart Cima Neve screen, or a Da Lite HD Pro. screen - just to name two. And if you plan on getting a 4K projector some day, a good screen surface is even more important. After owning my own theater for over 12 years, I just don't think going cheap on the screen is worth it.
DavidHir likes this.
post #7 of 7 Old 09-05-2014, 03:15 PM
DavidHir's Avatar
Liked: 1320
Agreed with Craig. The quality of your screen is very important and in essence 50% of the image you see with a front projection experience. Screens are typically not something you are going to upgrade very often, so why not get a good one?
DavidHir is offline
Reply Screens
