Whats the cheapest tab tensioned 120" motorized screen? - AVS Forum | Home Theater Discussions And Reviews
Old 08-28-2014, 09:50 PM - Thread Starter
johnny13oi's Avatar
Hey guys I am thinking about moving up to a projector setup and was wondering whats the cheapest tab tensioned 120" motorized projector screen I can get?
johnny13oi is offline
Old 08-29-2014, 06:28 AM
EVfan's Avatar
Elite Screens Starling Series
JVC RS46 with Elite Starling Tab-tensioned 100" screen
Samsung 63" PNC 7000
Marantz SR5009
Kef Q500 front L&R
Kef Q200c Center
Kef HTS 3001 Rears
EVfan is offline
Old 08-30-2014, 06:00 PM - Thread Starter
johnny13oi's Avatar
Even those seem pretty expensive for what I am looking for. How about either a cheap manual pull down or a cheap motorized one on eBay? I know those are not necessarily the best quality but I am on a very tight budget here. Which would you rather do?
Old 08-31-2014, 05:28 AM
EVfan's Avatar
I had trouble finding a tab-tensioned manual pull down screen. Is it just a screen you will use for a little while before upgrading? If you're just using for a little while, you may be able to get away with a non tensioned screen, until your budget grows. The Elite is super cheap with all features considered. Mine was ceiling mounted, and I needed drop, Elite gave me that, RF and IR remote included, super easy mounting system.
Marantz SR5009
Kef Q500 front L&R
Kef Q200c Center
Kef HTS 3001 Rears
EVfan is offline
