Vutec announced a new "zero bezel" frame, the Vision BWX, with LED backlighting that intended to be used when the projector is off to make the screen a more attractive element in the room. (I immediately thought about using it for a bias light, but then I realized that's not necessary for a typical projected image.) The new frame can be outfitted with four different ISF-certified Vutec materials.
The other Vutec news is an upgrade to the Vision XL-III motorized housing, which can now be ordered with Lutron mechanicals instead of the standard Somfy parts. This allows better integration with other Lutron products, such as lighting and shades, and it's much quieter than the Somfy. Of course, this upgrade increases the cost, but if you have lots of Lutron devices in your home theater, it could be well worth it.
Return to Master CEDIA 2014 Thread
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
