Have I ruined my Da Lite screen? - AVS Forum
 1Likes
  • 1 Post By ProjectionHead
Old 10-08-2014, 12:30 PM - Thread Starter
muzikool's Avatar
I have a 106" Da Lite Cinema Contour (fixed frame) screen and as of last night it has a spot on it (see photo). I had noticed a small, round, clear sticky spot on the screen, and so I grabbed a cloth to clean it. I've done this before with the same cloth -- one of those that comes with glasses -- and I just used water. I rubbed the spot for a few seconds and then I saw this brownish spot appear. The spot I was cleaning had no color to it, and the cloth was clean, so I don't know what caused this. I immediately tried cleaning the new spot with mild soap, but it wouldn't come off. Any suggestions? I'm concerned that I will need to replace the screen material, which will run about $450.
Media Room
Mitsubishi HC6800 1080P Projector with Darbee Darblet Video Processor
106" Da-Lite 90271V Cinema Contour High Contrast Cinema Vision Screen
Denon AVR-2809CI
Oppo BDP-93 Blu-ray Player
Energy v6.2 Towers / Energy v5.2 Center / Boston Acoustics HS50 surrounds / Klipsch RW-12D Sub
muzikool is offline
Old 10-09-2014, 09:28 AM
ProjectionHead's Avatar
Quoted: 13 Post(s)
Attachment 300666
What is the name of the surface on this screen?
ProjectionHead is offline
Old 10-09-2014, 09:48 AM - Thread Starter
muzikool's Avatar
Media Room
Denon AVR-2809CI
muzikool is offline
Old 10-09-2014, 09:55 AM
Quoted: 13 Post(s)
Is the spot still sticky? If so, the discoloration may be dirt/fiber from the cloth you used to clean it. Mild soap & water is the method that Da-lite suggests for cleaning, but if that didn't clean off the gunk "denatured alcohol" is the next step up (per Da-lite)
Let me know how it goes!
http://www.homedepot.com/p/Klean-Str...5003/202249513
sparky7 likes this.
