133 inch Da-lite too big for me ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-08-2014, 01:44 PM - Thread Starter
dllhg's Avatar
Quoted: 14 Post(s)
About to pull trigger on this screen. Locally for a small fraction of the regular price. I orginally wanted a 120 inch 125 max. Looking at calculators etc online seemed like 120 was on the edge for picture clarity etc. I will be 13-14 feet from screen. Projector will be a Benq W1500. Is this too large ? could I just throw a 120 inch image on the screen and be good ? Hear 3D you want to decrease image size for brightness too. Maybe 100-110 inches.
Thoughts ?
model is 84402 65X116 inches. Giant.
dllhg is offline
post #2 of 12 Old 10-10-2014, 12:57 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3041 Post(s)
Liked: 2973
Thoughts ?
Most projectors can easily light up a 120" diagonal screen. 133" - maybe - what is the screen material ? Are you getting a killer deal on a demo screen ?
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #3 of 12 Old 10-10-2014, 06:10 PM - Thread Starter
dllhg's Avatar
Quoted: 14 Post(s)
Seems like maybe it was a good thing I got the bigger one. Won't have to upgrade. Not a demo. Was from craigslist personal. Guy had a few of them and even had a 180 Da-lite for $1000. Top of the line. Never installed. Wires on it had never been terminated so I believe him. Such good quality it weighs 160 lbs ! Having a professional installer look at my set up tonight. Looks like too much for me to tackle honestly. Made to be recessed into ceiling. After seeing it I would really like that. Screen would be little higher that way too.
Very excited Now.
dllhg is offline
post #4 of 12 Old 10-10-2014, 06:12 PM - Thread Starter
dllhg's Avatar
Quoted: 14 Post(s)
Sorry it is matte. Bright white I think. Not sure I think it might be 1:1.
dllhg is offline
post #5 of 12 Old 10-12-2014, 07:35 PM
RRF
RRF's Avatar
Quoted: 22 Post(s)
You never mentioned the most critical metric...the throw distance.
133" is pretty big @ 13-14'.
The closer the projector is to the screen the brighter the image.
But, the closer the projector is to the screen, the more zoom is required to fill the screen.
The more zoom you use, the less detail in the picture.
The bitrate from a bluray may be high enough to provide an acceptable picture at a certain throw distance,
but a cable channel source may be unacceptable.
RRF is online now
post #6 of 12 Old 10-13-2014, 08:34 PM - Thread Starter
dllhg's Avatar
Quoted: 14 Post(s)
Wow, I would have thought the closest you could get it would be best for detail. Detail is important to me. I can actually mount the projector 20-21 feet away. Would be better placement for me. I need to find out the ideal throw on this projector it would seem.
dllhg is offline
post #7 of 12 Old 10-14-2014, 09:09 AM
RRF
RRF's Avatar
Quoted: 22 Post(s)
By increasing the zoom as you move the projector closer, you are spreading the light out to pass through more of the lens, which increases the potential for distortions. Of course, this depends on the quality ($$) of the lens. This is why a perfect focus across the entire screen is usually unattainable.
You just have to find the "sweet spot" for your seating position, picture quality expectations, environment and equipment. According to the Benq website, your W1500 projector has "...the flexibility of placing the projector in any room, regardless of size and brightness!"
RRF is online now
post #8 of 12 Old 10-14-2014, 12:38 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2973
Where did you get this ? I've got a Sony VW600 and a 3 chip DLP about as close as they can get to my 128" diagonal screen ( 14' throw ) - there is no loss of detail. What you don't want to do is use the extreme end of the lens - either end of the zoom range. I'm a little ways from maximum zoom.
post #9 of 12 Old 10-14-2014, 08:11 PM
RRF
RRF's Avatar
Quoted: 22 Post(s)
Well I have never seen a projector with a perfect zoom yet.
The effects may not be visible with regular content, but focus or sharpness test patterns do reveal distortion.
But these short throw projectors do get better every year.. due to improved optics.
The W1500 apparently has lots of light , includes ISFccc controls, and calibrates well.
But the W1500 reportedly loses 500 lumens from min to max zoom, but only 11% at mid zoom.
http://www.projectorreviews.com/benq...on-settings-1/
I also prefer mid zoom on all projectors, unless their performance demonstrates differently.
Also, in case the screen size changes in the future, you won't have to move the projector.
With a PPI of 16.5, viewed at 13', I know I would be picking my throw distance very carefully.
RRF is online now
post #10 of 12 Old 10-17-2014, 12:20 AM - Thread Starter
dllhg's Avatar
Quoted: 14 Post(s)
Thanks for all the input. Decided to go mid throw. I think I am going to do 13-14 feet. 14 would put it one foot behind where my head is reclined in chair. Throw for that size is 10.5 to 16.5 feet. 13 would be right in middle but would be right over my head. Worried about the noise from projector.
dllhg is offline
post #11 of 12 Old 10-17-2014, 10:30 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2973
Good decision IMO. I find that having the projector behind me makes it less noticeable - sort of " out of sight, out of mind " !
post #12 of 12 Old 10-17-2014, 01:56 PM
ProjectionHead's Avatar
Quoted: 27 Post(s)
noise and heat...I would try to position behind you if possible
ProjectionHead is offline
Reply Screens
