Goo Systems GooToob? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-30-2014, 09:02 AM - Thread Starter
Mbosco's Avatar
Quoted: 16 Post(s)
Does anyone have any feedback on the GooToob screens? I've heard of Goo Systems for some time, but not familiar with this "screen in a toob". For those not familiar, the new screen is not the paint systems they've used before (I'm no painter), but a wallpaper like application that gets mounted to the wall. I've searched and found remarkably little. So far the only real review I seen has been here: http://thewirecutter.com/reviews/best-projector-screen/
The only downsides noted are that it does require self install, but otherwise it seems to compare favorably with some of the highest cost screens available (i.e. Studiotek). The reviewer (Chris Heinonen) provided this as a summary, "Once I had it up, the GooToob presented an almost flawless image, with practically no color shift, an even gain (0.95 as measured, very close to the 1.0 it’s rated at), and a very pleasing surface overall. It offers up a screen surface that even the most critical viewer would be happy with."
If the review is accurate, this would seem to be a great option for a relatively light controlled space and permanent installation. Just wondering if anyone has thoughts or any direct experience. I only found one mention of it on AVS and the person referenced the first time it was being bought in the US. Perhaps this is just newly distributed here???
Last edited by Mbosco; 12-30-2014 at 09:11 AM. Reason: spelling and added info on the screen
Mbosco is offline
post #2 of 5 Old 12-30-2014, 10:52 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
This product needs to be moved to the Screens Forum as it is obviously outside of the DIY domain. Please contact a Moderator to have your Thread relocated.
MississippiMan is offline
post #3 of 5 Old 12-30-2014, 11:44 AM
Ftoast's Avatar
Quoted: 1918 Post(s)
Liked: 624
From what I've read the GooToob is a very nice white screen for anyone looking to trade a little work (made much easier with a second pair of hands) instead of paying through the nose.
An even cheaper and easier alternative if you've got a smooth wall (which I'm assuming the GooToob requires to some extent) would be simply rolling on two coats of flat/matte white paint and buying $20-40 worth of the same velvet tape that the GooToob uses for a border from a craft store.
The flat white paint doesn't show roller-marks and hides wall blemishes really well, so it's an excellent paint for a non-painter. Just grab a pair of 1/4" roller-pads so you don't reuse pads for the second coat.
It gives a neutral-white 0.95gain screen that disappears behind the image just like the Goo, except it costs less than $20 for everything besides the border and can easily be made by one person.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #4 of 5 Old 12-30-2014, 12:02 PM - Thread Starter
Mbosco's Avatar
Quoted: 16 Post(s)
Will do. I thought this one was kind of borderline DIY versus a straight product. I'll ask to have it moved.
AVS Moderators, please move to the main screen section as appropriate.
Mark
Mbosco is offline
post #5 of 5 Old 12-30-2014, 04:02 PM
Liked: 806
Mark
No worries....
And as Ftoast stated, DIY Screens has many viable options that easily compare / measure up to / exceed Mfg offerings. All ya gotta do is want something really special that you can be proud you created.
Your choice should center upon cost vs performance vs work ethic. The range of choices within DIY Screen making is pretty wide.
Reply Screens
