Screen Gain - AVS | Home Theater Discussions And Reviews
post #1 of 2 Unread Today, 10:18 AM - Thread Starter
crapel413's Avatar
Screen Gain
I'm ready to finally purchase a screen but have a question. I think we decided on going with 110" Criterion in the 1.78 ratio. I'm not sure if I should go Cinema White or Brilliant White. I have spent quite a bit of time reading the pros and cons of 1.0 Gain to 1.4 Gain. My room is a dedicated theatre with full light control. I'm using an Epson 8350 projector that is 13' from the screen. The front row eyes are about 13' from the screen and the back row is about 19 and a half feet from the screen. I have a 12" riser for the back row. The ceiling is black and the walls are a dark purple in matte finish. I'll attach a picture for reference. Carpeting which has been installed since picture was taken is a mix of black and grey's.
Thanks in advance for the advice.
Chris
ID:	510058   Click image for larger version
crapel413 is online now
post #2 of 2 Unread Today, 11:00 AM
airscapes's Avatar
Quoted: 131 Post(s)
Liked: 140
Chris
White. You have the light control, a reasonably sized screen, and plenty of light for that size screen size. why do you want gain and the image artifacts that go with it?
If you have not seen this screen report, take a read, lot of info to help understand all the aspects that make a good screen.
http://www.accucalhd.com/documents/a...een_report.pdf
airscapes is online now
Reply Screens
