Velcro vs snap-on screens - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-1999, 09:07 PM - Thread Starter
jcpom's Avatar
What are the pros and cons of front projection screens that use velcro vs snaps for attaching to the frame? Also, since I will be moving my soon-to-be-purchased screen to a new location next year, how difficult is it to disassemble an aluminum frame? Thanks.
jcpom is offline
Old 10-25-1999, 07:05 AM
Tim Wilkins's Avatar
I have the Draper Cineperm that uses the
snaps. I don't know how a screen that uses
velcro could stay tight in my opinion. I
know they sell these but I would think that
they would eventually pull loose. My Draper
that uses the snaps is pulled tight with no
wrinkles. Actually quite a few of the snaps
were hard to snap together it was that
tight. The screen surface is almost like a
percussion drum surface. The frame on mine
would be difficult to break down, not
impossible however.
Tim Wilkins is offline
