RPTV Screen for LCD or DLP projector? - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2000, 11:50 AM - Thread Starter
TSHA222's Avatar
Liked: 71
OK, this seems like it will work but I wanted some opinions. Here is my deal.... My wife and I are building a new home next year. I will be dedicating a room to HT but I also want a nice media room/living room system. I have an oportunity to buy aburned-out Proscan 80" RPTV for $150. It is literally burned out. Lighting hit it and the inside is melted. My idea was to take the screen (which is in perfect condition) and build it into the wall with either an LCD or DLP projector mounted behind. I would probably utilize a mirror assembly to cut the depth. Is this going to work? Are RPTV screens different than those sold by Stewart, et al? If not, then I am going to jump on this quick!
CHRIS WHTIE
TSHA222 is offline
Old 02-09-2000, 04:39 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Chris,
That's a great price.
Possible complications are mismatched Fresnel screen focal length (RPTV's have much shorter throw distances than projectors and possible insufficient Fresnel and lenticular pitches, which could cause aliasing with fixed-pixel displays.
The best thing would be to grab a projector with the same resolution and throw distance as the one you'll be using and try it with the screen to see if the picture is acceptable.
Noah
Noah
noah katz is offline
