Opinion on DaLite Video spectra 1.5? - AVS Forum | Home Theater Discussions And Reviews
Old 02-03-2000, 02:31 AM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
This is a pearleseant material with a gain of 1.5. I haven`t seen it, but consider it to be an alternative if I buy a screen with moderate gain. I will use it with a Barco 800 CRT projector.
Gunnar
Gunnar is offline
Old 02-06-2000, 11:47 AM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
I have the model B myself, but with the matte white material. It has wrinkles, and I can`t get rid of them. I`ve tried to dismantle the screen, but couldn`t find a obvious solution. Will build a custom curved screen instead. May need some screen material, but haven`t deceided yet if I want gain or not
Gunnar
Gunnar is offline
Old 02-09-2000, 04:24 PM
Dennis Nicholls's Avatar
I have this material in the Model C rollup screen. I would guess it's about right for my CRT projector in terms of gain, but the wrinkles are more noticeable than I would have guessed.
I'm going to make a set of sticks and clamps to serve as a poor-man's tabtensioner. I'll try to make a silk purse out of this sow's ear. Will post after trying this experiment.
Feline videophiles Condoleezza and Dukie
Dennis Nicholls is offline
Old 02-10-2000, 03:17 AM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
I`ll probably replace the Model B with a permanently tensioned screen. I plan to buy Draper M2500 fabric and staple it to the back of a wooden frame. The fabric is less than 40% of the price on a Draper Cineperm screen
Gunnar
Gunnar is offline
Old 02-12-2000, 03:22 AM
Mike2's Avatar
Gunnar.
Will you share your source for purchasing the Draper screen material? Not listed in the AV Science quickstore.
Mike
Mike2 is offline
Old 02-13-2000, 03:36 AM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
No problem Mike,
polivision@aol.com
I don`t think they have a WEB site, but they have been helpful answering my questions per e-mail. Tehy claim to have the lowest prices, and also offers several brands. Their price on a 92"x69" piece of Draper M2500 fabric is $ 195.
I`ve still not deceided on fabric. The streaking problem on the M2500 conserns me a bit. Maybe worth while to have a look at Stewart Video Matte 2.0?
Gunnar
Gunnar is offline
