AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   How to Figure Correct Gain Selection (http://www.avsforum.com/forum/23-screens/18897-how-figure-correct-gain-selection.html)
gages 02-05-2000 04:58 PM
How does one determine the correct screen gain when ordering a new screen.
I just received a Vutec Matte White screen w/ a 1.0 gain it was supposed to have been the 1.3 fabric but they messed up the order.
I am concerned that I may need a higher gain.
My configuration is as follows:
Screen size = 59 x 89
Seating distance = 12ft
Projector Distance = 17'
Projector Type = DILA (rated at 1000 Lumens but more likely ~500 lumens)
Steve
Donald Bennett 02-13-2000 01:24 PM
gages,
fL = (AL x SG) / ((SWI x (SWI x 0.67)) / 144)
where:
AL = Ansi Lumens
SG = Screen gain
SWI = Screen Width in Inches
fL = Footlamberts (10 recommended minimum for front projection).
This takes into consideration the phosphor utilization even with widescreen aspect ratios.
Don
Donald Bennett 02-13-2000 01:27 PM
Oops,
Should have been:
fL = (AL x SG) / ((SWI x (SWI x 0.75)) / 144)
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
